endelwar
(Manuel)
July 6, 2020, 10:48am
1
Debian 9.12, PHP 7.2.31 on a KVM machine.
Caddy installed from official deb package from https://apt.fury.io/caddy
I use default caddy.service file, this one dist/caddy.service at master · caddyserver/dist · GitHub
cfl.man-at-work.it {
encode zstd gzip
root * /srv/www/cfl/current/public/
tls mymail@example.com
php_fastcgi unix//run/php/php7.2-fpm.sock
output file /var/log/caddy/cfl.log
I’m using Deployer to deploy my code to the server: Deployer uses a symlink based directory schema pointing current release (/srv/www/cfl/current/public/) to last successful deployed version.
Due to the nature of PHP opcache the new release path is not read by PHP because it’s cached and symlink path doesn’t change form PHP prospective.
A workaround for this issue is to restart php-fpm or manually flush opcache at every release.
Nginx has a special entry in config file that resolves symlinks and give php-fpm the real path of root directory called $realpath_root, so going from this config
fastcgi_index index.php;
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param DOCUMENT_ROOT $document_root;
to this
fastcgi_param SCRIPT_FILENAME $realpath_root$fastcgi_script_name;
fastcgi_param DOCUMENT_ROOT $realpath_root;
Nginx resolve the real path of the symlink and pass it to php-fpm.
Is it possible to obtain the same behaviour in Caddy 2.1?
none
Manually restarting php-fpm after each deploy works as expected.
Here the issue is explained way better than above:
In PHP =< 5.4, there was APC. And in APC, there was the apc.stat option to check the timestamps on files to determine if they’ve changed, and a new version should be cached. However, in PHP 5.5+, it introduces OPCode Caching as an alternative to...
https://tech.yappa.be/php-fpm-executing-old-code-after-symlink-deploy
I think you can use the env subdirective of php_fastcgi for this.
Sorry, on my phone so I can’t dig further.
endelwar
(Manuel)
July 6, 2020, 9:37pm
3
I looked at fastcgi source code and I don’t think that setting root in env subdirective will help: there should be a filepath.EvalSymlinks somewhere to obtain the desired result.
Ah okay. It should be pretty easy to add a new subdirective to do that then, sounds like. If you’d like to write a PR, that’d be great!
endelwar
(Manuel)
July 7, 2020, 6:12am
5
Golang rookie here, but I’ll give it a try on weekend
If you’re able to hard-code a change to make it work for your usecase, I can help you wire it up as a new configuration option.
Building from source is very easy - there’s a section in the docs that explains how to do it!
Let me know if you have any questions or need help!
endelwar
(Manuel)
July 18, 2020, 2:04pm
7
Just opened a PR to solve this issue, any feedback is welcome!
caddyserver:master ← endelwar:resolve-root-symlink
opened 02:03PM - 18 Jul 20 UTC
This PR will enable resolving real path on symlinked releases.
When using a sym… link based directory schema PHP, through Caddy, will serve old symlinked directory instead of resolving the actual real path of new released code: due to the nature of PHP opcache the new release path is not read by PHP because it’s cached and symlink path doesn’t change form PHP prospective.
Adding the new `resolve_root_symlink` subdirective on php_fastcgi will enable resolution of real path, thus permitting Caddy to server the actual codebase instead of the old one.
See [this forum post](https://caddy.community/t/resolve-real-path-on-symlinked-releases/8963) to further details.
Example Caddyfile:
http://example.test {
root * /var/www/deploy/current
php_fastcgi 127.0.0.1:9000 {
Where `/var/www/deploy/current` is a symlink to real directory
matt
(Matt Holt)
July 20, 2020, 6:16pm
8
Nice job, thanks for the contribution @endelwar !
system
(system)
Closed
August 5, 2020, 10:51am
9
