xcaddy build --with GitHub - caddy-dns/dnspod · GitHub
–with github.com/lucas-clemente/quic-go@v0.25.0
OS: Ubuntu 20.04 LTS
Golang: go1.18
./caddy run -watch
*.airdb.net {
#dns dnspod {env.DNSPOD_TOKEN}
dns dnspod 307575,AAAAAAAAA
encode {
#zstd
gzip
@not_static {
not {
path /BingSiteAuth.xml /robots.txt
path /favicon.ico
#root /robots.txt /srv/www
#file_server
# https://caddyserver.com/docs/caddyfile/directives/reverse_proxy
@service host dev.airdb.net
reverse_proxy @service http://127.0.0.1:7000
@serviceA host a.airdb.net
reverse_proxy @serviceA http://127.0.0.1:8000
@serviceB host b.airdb.net
reverse_proxy @serviceB http://127.0.0.1:9000
root * /srv/www
Using this Caddyfile can get wildcard certs successfully, and reserver_proxy by multi-domain.
The issue is:
Is there a way to set the static favicon or robots to use the same local file?
