Is it possible to run regex replacements on placeholders in server blocks?
One use case I have is taking the tls_on_demand ?domain=<domain>
query parameter and passing it to consul via a rewrite
# pseudo code
on_demand_tls {
ask http://localhost/ask
http://localhost {
rewrite * “/v1/agent/service/${replace(query.domain, “.”, “_”
reverse_proxy consul:8500
And another is using the host header in a dynamic upstream block
dynamic srv {
name “${replace(host, “.”, “_”)}”
It’s not currently possible to apply replacements to queries, but you could do it with rewrite: Implement `uri query` operations by armadi1809 · Pull Request #6120 · caddyserver/caddy · GitHub once that’s merged.
It might be possible to do it with a two-step rewrite. This might work:
rewrite * /v1/agent/service/{query.domain}
uri replace . _
Edit: this seems to work:
:8881 {
rewrite * /foo/bar/{query.domain}?
uri replace . _
respond {uri}
$ curl -v http://localhost:8881/foo?domain=a.b.c.d.e.f.g
/foo/bar/a_b_c_d_e_f_g
Thanks — that’s great! I’ll probably have to write a module to handle more complex use cases in the future, but for now this is okay.
For posterity, the solution I’m using to check if a service is in the consul catalog
http://127.0.0.1 {
rewrite * /v1/catalog/service/{query.domain}?
uri replace . -
reverse_proxy consul.service.consul:8500 {
@not_registered {
status 200
header Content-Length 2
replace_status @not_registered 400
system
(system)
Closed
4
