I want to deny download access, but not work.
myplugin code
type responseWriterWrapper struct {
*caddyhttp.ResponseWriterWrapper
wroteHeader bool
match bool
func (rww *responseWriterWrapper) WriteHeader(status int) {
if rww.wroteHeader {
return
rww.wroteHeader = true
ct := rww.Header().Get("Content-Type")
cd := rww.Header().Get("Content-Disposition")
if strings.Contains(ct, "octet-stream") || cd != "" { // download header match
rww.match = true
rww.Header().Set("Content-Type", "text/html; charset=utf-8")
rww.Header().Del("Content-Disposition")
rww.Header().Del("Content-Length")
rww.ResponseWriterWrapper.WriteHeader(http.StatusForbidden)
return
rww.ResponseWriterWrapper.WriteHeader(status)
func (rww *responseWriterWrapper) Write(d []byte) (int, error) {
if !rww.wroteHeader {
rww.WriteHeader(http.StatusOK)
if rww.match { // if download discard data
return len(d), nil
return rww.ResponseWriterWrapper.Write(d)
func (h *Handler) ServeHTTP(w http.ResponseWriter, r *http.Request, next caddyhttp.Handler) error {
ww := &responseWriterWrapper{
ResponseWriterWrapper: &caddyhttp.ResponseWriterWrapper{ResponseWriter: w},
err := next.ServeHTTP(ww, r)
// It's not work
w.Header().Set("abc", "abc")
_, _ = w.Write([]byte("deny download"))
return err
I set response header (w.Header().Set("abc", "abc")
) and rewrite response (w.Write([]byte("deny download"))
). When I curl,didn’t get the desired result
order myplugin after encode
auto_https off
a.com:443 {
myplugin
tls a.crt a.key
reverse_proxy https://11.3.4.1 {
trusted_proxies private_ranges
tls
tls_insecure_skip_verify
