JackBailey
(Jack Bailey)
1
1. Caddy version:
v2.6.3 h1:QRVBNIqfpqZ1eJacY44I6eUC1OcxQ8D04EKImzpj7S8=
Docker compose using a Dockerfile using xcaddy
Ubuntu 22.04
Docker with the Compose plugin
docker compose up -d
(default) {
format filter {
wrap json
fields {
request>remote_ip replace `{{.Req.Header.Get "CF-Connecting-IP"}}`
output file /srv/log/access.log
ip.example.com {
import default
respond "ok"
I’m trying to set the remote_ip in the log file to the forwarded IP from cloudflare, so goaccess and crowdsec can show the proper IPs.
"level": "info",
"ts": 1676381547.249779,
"logger": "http.log.access.log30",
"msg": "handled request",
"request": {
"remote_ip": "{{.Req.Header.Get \"CF-Connecting-IP\"}}",
"host": "ip.example.com",
"headers": {
"X-Forwarded-For": [
"123.456.789.10"
"Cf-Connecting-Ip": [
"123.456.789.10"
Replacing `{{.Req.Header.Get “CF-Connecting-IP”}}` with request>headers>X-Forwarded-For
log (Caddyfile directive) — Caddy Documentation Shows a similar usage but for IP masking
That’s not possible, currently. Log writers can’t use placeholders or Go templates.
In a future version (probably v2.7.0) we’ll have first-class support for logging the real client IP:
system
(system)
Closed
3
