Hello,
I Use Caddy as a revers proxy service and SSL of my domains.
Now I have 4 domain in my Caddyfile and I need renew SSL one of this 4 domains.
I know Caddy automatically renew all of SSL but for any reason I need renew manually.
Can I use this command for renew one of my domain:
curl -X POST “http://localhost:2019/id/example.com/renew”
I have a program that connects to my web server via code and due to the changes made by Let’s Encrypt in CA Root Chain related to SSL I need to update my SSL and I can’t stay until Autorenew.
I found these two commands in various sites and I want to make sure of their correct or not
I found that cammand in chatGPT.
Then That’s not correct?
I found some .key and .crt of my domains in this directory:
/var/lib/caddy/.local/share/caddy/certificates/acme-v02.api.letsencrypt.org-directory/
If I remove .key and .crt of my specific domain and after restart Caddy service, I automatically renew key and crt for just my specific domain?
ACME means Automatic Certificate Management Environment, manually isn’t the first choice. But can still be helpful at times. Just something to consider.
