Renew on-demand TLS certificates in Caddy
We’re using Redis as a TLS storage and we need to re-issue some certificates from customers. The TLS certificate generated on-demand. I’ve deleted the certificates from Redis (all keys from a given domain), but Caddy is still serving the TLS certificate.
I assume it’s cached in memory?
Is there a way to clear Caddy’s cache without a restart?
I’ve tried caddy reload -c /etc/caddy/Caddyfile --force
it outputs: INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""} but it doesn’t re-issue the certificate.
n/a
caddy:2.7.6-builder docker container.
Docker containers.
Docker
docker-compose up
    build:
      dockerfile: ./caddy/caddy.Dockerfile
      - REDIS_HOST=redis
      - REDIS_PORT=6379
      - REDIS_USERNAME=default
      - REDIS_PASSWORD=redis
      - HTTP_CHALLENGE_SERVER=http-challenge
    cert_issuer zerossl {$ZEROSSL_API_KEY}
	on_demand_tls {
		ask http://{$HTTP_CHALLENGE_SERVER}/ask
	storage redis {
		host {$REDIS_HOST}
		port {$REDIS_PORT}
		username {$REDIS_USERNAME}
		password {$REDIS_PASSWORD}
	servers {
		metrics
https://* {
	tls internal {
		on_demand
    @www header_regexp nonwww Host ^(www\.)(.*)
	@no-www host www.{args.0}
	handle @www {
		redir https://{re.nonwww.2}{uri}
	@non-www not header_regexp Host ^(www\.)(.*)
	handle @non-www {
		redir https://www.{host}{uri}
    respond 404
Why do you need to reissue the certificates?
The only way to manually evict certs from Caddy’s cache currently is to restart the process. Reloads persist certs.
You should have no reason to reissue the certificates. If they were revoked by the CA, Caddy would notice via the OCSP responder and reissue new ones on its own. Otherwise, they continue to be valid until they expire.
