Remote_ip validates as "unrecognized subdirective"
v2.4.5
Running in a docker container.
Used the following image using latest tag: caddy - Official Image | Docker Hub
Ubuntu 20.04.3 LTS host
Docker version: 20.10.8
N/A
N/A
uptime.itss.com.au {
        reverse_proxy localhost:3001 {
                remote_ip 122.230.17.30/32
When I run sudo caddy validate I get the below error message and it doesn’t restrict to my IP address:
validate: adapting config using caddyfile: parsing caddyfile tokens for ‘reverse_proxy’: Caddyfile:9 - Error during parsing: unrecognized subdirective remote_ip
  1. Tried reformatting with sudo caddy fmt
  2. Tried to use remote_addr instead as I found that on some caddy forum posts
Request matchers don’t go within other handler directives.
Read the top of the Request Matchers docs, you need to define a named matcher which you’ll then apply to reverse_proxy.
Aha! Thank you!
