v2.2.1 (via caddy:2-alpine)
docker + docker-compose
Ubuntu 20.04.1 LTS
Docker version 19.03.13
docker-compose version 1.24.1
version: "3.7"
image: lucaslorentz/caddy-docker-proxy:ci-alpine
ports: ...
volumes: ...
labels:
caddy.email: xxx
caddy.acme_ca: xxx
# snippet definitions
caddy_0: '(www-redirect)'
caddy_0.redir: 'https://www.{hostport}{uri}'
caddy_1: '(dns-challenge)'
caddy_1.tls.dns: 'lego_deprecated easydns'
caddy_2: example.com
caddy_2.import: 'www-redirect'
whoami-private-working:
image: jwilder/whoami
- docker_web
labels:
caddy: 'private-working.example.com'
caddy.reverse_proxy: "{{upstreams 8000}}"
caddy.@public_networks.not.remote_ip: '192.168.0.0/16 172.16.0.0/12 10.0.0.0/8'
caddy.import: 'dns-challenge'
caddy.respond: '@public_networks 403'
caddy.respond.close:
Caddyfile generated by caddy-docker-proxy:
email xxxxxxxx
(dns-challenge) {
dns lego_deprecated easydns
(www-redirect) {
redir https://www.{hostport}{uri}
example.com {
import www-redirect
private-working.example.com {
@public_networks {
not {
remote_ip 192.168.0.0/16 172.16.0.0/12 10.0.0.0/8
import dns-challenge
respond @public_networks 403 {
close
reverse_proxy 172.25.0.8:8000
The above works. I am ONLY able to hit private-working.example.com if I’m on my private network. Here’s the rub: I’m trying to factor this out into something that makes it easy to declare a Docker container as private without a bunch of configuration.
I tried defining snippet like this and it doesn’t work (public networks can access the site):
(internal-only) {
@public_networks {
not {
close
private-not-working.example.com {
import dns-challenge internal-only
reverse_proxy 172.25.0.9:8000
What I would REALLY like to do is declare my Caddyfile so that all sites are private-network-only by default, but with a piece of configuration I can make a specific site be publicly exposed. It would look something like this:
email xxxxxxxx
(make-me-externally-available) {
# what do I do here to make this work?
private.example.com {
public.example.com {
import make-me-externally-available
