RHEL 8.4
❯ uname -msr
Linux 4.18.0-240.15.1.el8_3.x86_64 x86_64
Caddy is ran as an unprivileged user using an executable in the same directory as the config and client certificates.
sudo setcap CAP_NET_BIND_SERVICE+ep <PATH_TO_CADDY>
./caddy run -config=caddy.json
N/A
Local Config:
"admin": {
"listen": "127.0.0.1:2020",
"config": {
"load": {
"module": "http",
"url": "https://<REDACTED>",
"header": {
"Authorization": [ "Bearer <REDACTED>" ]
Config from Remote:
"admin": {
"listen": "<REDACTED>:2020",
"identity": {
"identifiers": [
"<REDACTED>"
"issuers": [
"module": "internal",
"ca": "admin",
"lifetime": "1d",
"sign_with_root": false
"remote": {
"access_control": [
"public_keys": [
"<REDACTED>"
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
"<REDACTED>:443"
"routes": [
"@id": "<REDACTED>",
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"dial": "tcp\/<REDACTED>"
"match": [
"host": [
"<REDACTED>"
"terminal": true
"pki": {
"certificate_authorities": {
"local": {
"install_trust": false
"admin": {
"name": "Caddy",
"root_common_name": "<REDACTED>",
"intermediate_common_name": "<REDACTED>",
When making an API request with CURL to fetch the config, it returns the local config rather than the remote config.
curl --cert client.pem --key client-key.pem -k https://<REDACTED>:2021/config/ | jq
(Port is 2021 due to mTLS)
Returns the exact same config specified in the local caddy.json
, instead the remote or any merging of the two configs.
I’d expect that API request to return the remote config that was fetched.
❯ ./caddy run -config=caddy.json
2021/06/18 18:47:33.629 INFO using provided configuration {"config_file": "caddy.json", "config_adapter": ""}
2021/06/18 18:47:33.630 INFO admin admin endpoint started {"address": "tcp/<REDACTED_PRIVATE_IP>:2020", "enforce_origin": false, "origins": ["<REDACTED_PRIVATE_IP>:2020"]}
2021/06/18 18:47:33.772 INFO applying dynamically-loaded config {"loader_module": "http"}
2021/06/18 18:47:33.772 INFO autosaved config (load with --resume flag) {"file": "/home/matthew/.config/caddy/autosave.json"}
2021/06/18 18:47:33.772 INFO serving initial configuration
2021/06/18 18:47:33.772 INFO admin admin endpoint started {"address": "tcp/<REDACTED_PRIVATE_DOMAIN>:2020", "enforce_origin": false, "origins": ["<REDACTED_PRIVATE_DOMAIN>:2020"]}
2021/06/18 18:47:33.773 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/06/18 18:47:33.773 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2021/06/18 18:47:33.773 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00033ea10"}
2021/06/18 18:47:33.773 WARN pki.ca.local root certificate trust store installation disabled; unconfigured clients may show warnings {"path": "storage:pki/authorities/local/root.crt"}
2021/06/18 18:47:33.773 WARN pki.ca.admin root certificate trust store installation disabled; unconfigured clients may show warnings {"path": "storage:pki/authorities/admin/root.crt"}
2021/06/18 18:47:33.773 INFO pki intermediate expires soon; renewing {"ca": "local", "time_remaining": -2072927.773478879}
2021/06/18 18:47:33.773 INFO pki renewed intermediate {"ca": "local", "new_expiration": "2021/06/25 18:47:33.000"}
2021/06/18 18:47:33.773 INFO pki intermediate expires soon; renewing {"ca": "admin", "time_remaining": -2072927.773892499}
2021/06/18 18:47:33.774 INFO pki renewed intermediate {"ca": "admin", "new_expiration": "2021/06/25 18:47:33.000"}
2021/06/18 18:47:33.774 INFO tls cleaning storage unit {"description": "FileStorage:/home/matthew/.local/share/caddy"}
2021/06/18 18:47:33.774 INFO http enabling automatic TLS certificate management {"domains": ["<REDACTED_PUBLIC_DOMAIN>"]}
2021/06/18 18:47:33 [INFO] Certificate certificates/admin/<REDACTED_PRIVATE_DOMAIN>/<REDACTED_PRIVATE_DOMAIN>.crt expired 719h48m47.774966656s ago; cleaning up
2021/06/18 18:47:33 [INFO] Deleting certificates/admin/<REDACTED_PRIVATE_DOMAIN>/<REDACTED_PRIVATE_DOMAIN>.crt because resource expired
2021/06/18 18:47:33 [INFO] Deleting certificates/admin/<REDACTED_PRIVATE_DOMAIN>/<REDACTED_PRIVATE_DOMAIN>.key because resource expired
2021/06/18 18:47:33 [INFO] Deleting certificates/admin/<REDACTED_PRIVATE_DOMAIN>/<REDACTED_PRIVATE_DOMAIN>.json because resource expired
2021/06/18 18:47:33 [INFO] Deleting certificates/admin/<REDACTED_PRIVATE_DOMAIN> because key is empty
2021/06/18 18:47:33.775 INFO tls finished cleaning storage units
2021/06/18 18:47:33.872 INFO admin.identity.obtain acquiring lock {"identifier": "<REDACTED_PRIVATE_DOMAIN>"}
2021/06/18 18:47:33.872 INFO admin.remote secure admin remote control endpoint started {"address": "tcp/:2021"}
2021/06/18 18:47:33.872 INFO dynamically-loaded config applied successfully
2021/06/18 18:47:33.874 INFO admin.identity.obtain lock acquired {"identifier": "<REDACTED_PRIVATE_DOMAIN>"}
2021/06/18 18:47:33.875 INFO admin.identity.obtain certificate obtained successfully {"identifier": "<REDACTED_PRIVATE_DOMAIN>"}
2021/06/18 18:47:33.875 INFO admin.identity.obtain releasing lock {"identifier": "<REDACTED_PRIVATE_DOMAIN>"}
2021/06/18 18:47:33.876 WARN admin.identity stapling OCSP {"error": "no OCSP stapling for [<REDACTED_PRIVATE_DOMAIN>]: no OCSP server specified in certificate"}
2021/06/18 18:47:34.272 INFO admin stopped previous server {"address": "tcp/<REDACTED_PRIVATE_IP>:2020"}
2021/06/18 18:48:11.294 INFO admin.api received request {"method": "GET", "host": "127.0.0.1:2020", "uri": "/config/", "remote_addr": "127.0.0.1:39468", "headers": {"Accept":["*/*"],"User-Agent":["curl/7.61.1"]}}
2021/06/18 18:48:11.294 ERROR admin.api request error {"error": "host not allowed: 127.0.0.1:2020", "status_code": 403}
2021/06/18 18:50:10.840 INFO admin.api received request {"method": "GET", "host": "<REDACTED_PRIVATE_DOMAIN>:2021", "uri": "/config/", "remote_addr": "127.0.0.1:55172", "headers": {"Accept":["*/*"],"User-Agent":["curl/7.61.1"]}, "secure": true, "verified_chains": 1}
2021/06/18 18:50:16.051 INFO admin.api received request {"method": "GET", "host": "<REDACTED_PRIVATE_DOMAIN>:2021", "uri": "/config/", "remote_addr": "127.0.0.1:55180", "headers": {"Accept":["*/*"],"User-Agent":["curl/7.61.1"]}, "secure": true, "verified_chains": 1}
Not much I can try, I’m pretty convinced this is either a bug or is intentional behavior. I attempted to look through the code for the remote config loading but had no idea where I would possibly start trying to debug or figure this out.
