1. Output of caddy version:
v2.6.2
Bare-metal
FreeBSD 13.1-RELEASE-p2 FreeBSD 13.1-RELEASE-p2 GENERIC amd64
Any command that requires triggering build request on caddy website (including download caddy with plugins):
caddy upgrade
caddy add-package
#!/bin/sh
# PROVIDE: caddy
# REQUIRE: LOGIN DAEMON NETWORKING
# KEYWORD: shutdown
# To enable caddy, add 'caddy_enable="YES"' to /etc/rc.conf or
# /etc/rc.conf.local
# Optional settings:
# caddy_command (string): Full path to the caddy binary
# caddy_config (string): Full path to caddy config file
# (/usr/local/etc/caddy/Caddyfile)
# caddy_adapter (string): Config adapter type (caddyfile)
# caddy_directory (string): Root for caddy storage (ACME certs, etc.)
# (/var/db/caddy)
# caddy_extra_flags (string): Extra flags passed to caddy start
# caddy_logdir (string): Where caddy logs are stored
# (/var/log/caddy)
# caddy_logfile (string): Location of process log (${caddy_logdir}/caddy.log)
# This is for startup/shutdown/error messages.
# To create an access log, see:
# https://caddyserver.com/docs/caddyfile/directives/log
# caddy_user (user): User to run caddy (root)
# caddy_group (group): Group to run caddy (wheel)
# This script will honor XDG_CONFIG_HOME/XDG_DATA_HOME. Caddy will create a
# .../caddy subdir in each of those. By default, they are subdirs of /var/db/caddy.
# See https://caddyserver.com/docs/conventions#data-directory
. /etc/rc.subr
name=caddy
rcvar=caddy_enable
desc="Powerful, enterprise-ready, open source web server with automatic HTTPS written in Go"
load_rc_config $name
# Defaults
: ${caddy_enable:=NO}
: ${caddy_adapter:=caddyfile}
: ${caddy_config:="/usr/local/etc/caddy/Caddyfile"}
: ${caddy_command:="/usr/local/bin/${name}"}
: ${caddy_directory:=/var/db/caddy}
: ${caddy_extra_flags:=""}
: ${caddy_logdir:="/var/log/${name}"}
: ${caddy_logfile:="${caddy_logdir}/${name}.log"}
: ${caddy_user:="root"}
: ${caddy_group:="wheel"}
# Config and base directories
: ${XDG_CONFIG_HOME:="${caddy_directory}/config"}
: ${XDG_DATA_HOME:="${caddy_directory}/data"}
export XDG_CONFIG_HOME XDG_DATA_HOME
command="${caddy_command}"
caddy_flags="--config ${caddy_config} --adapter ${caddy_adapter}"
pidfile="/var/run/${name}/${name}.pid"
required_files="${caddy_config} ${caddy_command}"
start_precmd="caddy_precmd"
start_cmd="caddy_start"
stop_precmd="caddy_prestop"
# Extra Commands
extra_commands="configtest reload"
configtest_cmd="caddy_execute validate ${caddy_flags}"
reload_cmd="caddy_execute reload ${caddy_flags}"
caddy_execute()
/usr/bin/su -m "${caddy_user}" -c "${caddy_command} $*"
caddy_precmd()
# Create required directories and set permissions
/usr/bin/install -d -m 755 -o "${caddy_user}" -g "${caddy_group}" ${caddy_directory}
/usr/bin/install -d -m 700 -o "${caddy_user}" -g "${caddy_group}" ${caddy_directory}/config
/usr/bin/install -d -m 700 -o "${caddy_user}" -g "${caddy_group}" ${caddy_directory}/data
/usr/bin/install -d -m 755 -o "${caddy_user}" -g "${caddy_group}" ${caddy_logdir}
/usr/bin/install -d -m 700 -o "${caddy_user}" -g "${caddy_group}" /var/run/caddy
if [ -e ${caddy_logfile} ]; then
/bin/chmod 644 ${caddy_logfile}
/usr/sbin/chown root:wheel ${caddy_logfile}
else
/usr/bin/install -m 644 -o root -g wheel /dev/null ${caddy_logfile}
fi
caddy_start()
echo -n "Starting caddy... "
/usr/bin/su -m ${caddy_user} -c "${caddy_command} start ${caddy_flags} \
${caddy_extra_flags} --pidfile ${pidfile}" >> ${caddy_logfile} 2>&1
if [ $? -eq 0 ] && ps -ax -o pid | grep -q "$(cat ${pidfile})"; then
echo "done"
echo "Log: ${caddy_logfile}"
else
echo "Error: Caddy failed to start"
echo "Check the caddy log: ${caddy_logfile}"
fi
caddy_prestop()
local result
echo -n "Stopping caddy... "
result="$(caddy_execute stop 2>&1)"
if [ ${?} -eq 0 ]; then
echo "done"
exit 0
else
if echo "${result}" | grep -q "connection refused"; then
echo "admin interface unavailable; using pidfile"
return 0
else
echo "Error: Unable to stop caddy"
return 1
fi
fi
run_rc_command "$1"
# domain name.
m.ddns.net {
# Set up a reverse proxy:
reverse_proxy 10.0.1.1:8080
# Enable logging:
output file /var/log/caddy/m.ddns.net.access.log
# Caddy's structured log format:
format json
# Or, for Common Log Format:
# format single_field common_log
key_type p384
curves secp521r1 secp384r1 x25519
header / Strict-Transport-Security "max-age=31536000;"
4m.ddns.net {
# Enable logging:
output file /var/log/caddy/4m.ddns.net.access.log
format json
torrentm.ddns.net {
reverse_proxy 127.0.0.1:8080
# Enable logging:
output file /var/log/caddy/torrentm.ddns.net.access.log
format json
./caddy upgrade
2023/01/11 17:05:21.393 INFO this executable will be replaced {"path": "/usr/home/thomas/caddy"}
2023/01/11 17:05:21.393 INFO requesting build {"os": "freebsd", "arch": "amd64", "packages": ["github.com/corazawaf/coraza-caddy"]}
Error: download failed: download failed: HTTP 400: unable to fulfill download request (id=d92afa90-d6cd-459a-a54b-29323a984574)
The program hangs and the build is never fetched, so I guess the server isn’t able to build caddy for FreeBSD amd64 with some plugins.
I have the same result when I trigger caddy add-package on the same OS.
I tried to trigger the build for other environments (Windows, Linux) and it worked perfectly.
I also tried to download from the official website Download Caddy , it worked everytime excepted when I tried to download for FreeBSD with plugins.
The xcaddy command worked fine so I guess the error is on the server side.
