Reload stuck tho Valid configuration?
reload caddy stuck although configuration valid. Been trying to use on demand TLS to forward all www.example.com to example.com
>  caddy validate --config /etc/caddy/Caddyfile
2025/08/31 11:11:39.451	INFO	using config from file	{"file": "/etc/caddy/Caddyfile"}
2025/08/31 11:11:39.454	INFO	adapted config to JSON	{"adapter": "caddyfile"}
2025/08/31 11:11:39.457	INFO	http.auto_https	enabling automatic HTTP->HTTPS redirects	{"server_name": "srv0"}
2025/08/31 11:11:39.457	WARN	http.auto_https	server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server	{"server_name": "srv1", "http_port": 80}
2025/08/31 11:11:39.457	INFO	tls.cache.maintenance	started background certificate maintenance	{"cache": "0xc0003b9a80"}
2025/08/31 11:11:39.458	INFO	tls.cache.maintenance	stopped background certificate maintenance	{"cache": "0xc0003b9a80"}
2025/08/31 11:11:39.458	INFO	http	servers shutting down with eternal grace period
Valid configuration
> systemctl reload caddy
^C → It stuck!
Linux 6.14.0-23-generic #23-Ubuntu SMP PREEMPT_DYNAMIC Fri Jun 13 23:02:20 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
        on_demand_tls {
                ask https://myserver.com/check
http:// {
        redir https://{host} permanent
https:// {
                on_demand
        redir https://www.{host} permanent
5. Caddy logs
root@ubuntu:~# sudo systemctl stop caddy
root@ubuntu:~# sudo caddy run --config /etc/caddy/Caddyfile
2025/08/31 11:35:00.408	INFO	maxprocs: Leaving GOMAXPROCS=1: CPU quota undefined
2025/08/31 11:35:00.409	INFO	GOMEMLIMIT is updated	{"package": "github.com/KimMachineGun/automemlimit/memlimit", "GOMEMLIMIT": 431931801, "previous": 9223372036854775807}
2025/08/31 11:35:00.409	INFO	using config from file	{"file": "/etc/caddy/Caddyfile"}
2025/08/31 11:35:00.411	INFO	adapted config to JSON	{"adapter": "caddyfile"}
2025/08/31 11:35:00.414	INFO	admin	admin endpoint started	{"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2025/08/31 11:35:00.414	INFO	http.auto_https	enabling automatic HTTP->HTTPS redirects	{"server_name": "srv0"}
2025/08/31 11:35:00.415	WARN	http.auto_https	server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server	{"server_name": "srv1", "http_port": 80}
2025/08/31 11:35:00.415	INFO	http	enabling HTTP/3 listener	{"addr": ":443"}
2025/08/31 11:35:00.417	INFO	tls.cache.maintenance	started background certificate maintenance	{"cache": "0xc0000e0200"}
2025/08/31 11:35:00.418	INFO	http.log	server running	{"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2025/08/31 11:35:00.418	WARN	http	HTTP/2 skipped because it requires TLS	{"network": "tcp", "addr": ":80"}
2025/08/31 11:35:00.419	WARN	http	HTTP/3 skipped because it requires TLS	{"network": "tcp", "addr": ":80"}
2025/08/31 11:35:00.419	INFO	http.log	server running	{"name": "srv1", "protocols": ["h1", "h2", "h3"]}
2025/08/31 11:35:00.420	INFO	autosaved config (load with --resume flag)	{"file": "/root/.config/caddy/autosave.json"}
2025/08/31 11:35:00.420	INFO	serving initial configuration
2025/08/31 11:35:00.423	INFO	tls	cleaning storage unit	{"storage": "FileStorage:/root/.local/share/caddy"}
2025/08/31 11:35:00.425	INFO	tls	finished cleaning storage units
