Relative paths in html files do not work
I want to serve static html files. Those files are using relative paths “./abc” to other assets. This does not work because the base path is lost.
So, I can access host:86/munin/index.html.
But in that html file, it references other files and directories with “./otherdir/otherfile”.
With Caddy, the base path “/munin” is lost and the browser want to go to host:86/otherdir/otherfile.
This worked fine with Apache.
No errors.
Docker compose.
    build:
      context: .
      dockerfile: Dockerfile-caddy
    cap_add:
      - NET_ADMIN
      - "86:80"
      - "446:443"
      - "446:443/udp"
      - caddy
      - $PWD/site:/srv
      - $PWD/data:/data
      - $PWD/config:/config
      - type: bind
        source: /var/www/localhost/htdocs/munin
        target: /munin
        auto_https off
        order webdav before file_server
        handle_path /munin* {
                root * /munin
I am using handle_path because I am serving also other parts with other features (php, webdav).
Thanks!
You need handle_path /munin/*.
(This isn’t a Caddy issue, this is just how relative links work in HTML.)
Very cool, thank you for the quick response, this works.
I have seen this syntax in examples but did not think that this would fix my issue.
As expected, then host:86/munin did not work anymore.
But I was able to fix that with
redir /munin /munin/
outside the handle_path directives.
