I am trying to migrate from nginx and I need to use regular expressions in the hostname. Also, I am using a wildcard SSL certificate.
What is the recommended approach for this use case?
This is one example of the hostname regex ^(webview-|browser-|extensions-)?(?P<workspaceIDKey>[a-z0-9][0-9a-z\-]+).ws(?P<locationKey>-[a-z0-9]+)?.{$DOMAIN}
What I already tried:
I can write a middleware but would mean I will end up with one server definition like *.*.{$DOMAIN}.
I’m not sure how much of your regexp syntax is supported by Golang’s regexp engine, but you can play around on https://regex101.com/ to find out.
Are you bringing your own wildcard certificate to Caddy, or do you expect to use Caddy to automate it? Because Caddy can only issue single-level wildcard certificates. You could use On-Demand TLS though, if there’s not an inordinate amount of possible combinations of domains you want to allow.
@francislavoie thank you for the quick response.
That was exactly the first approach I took. My next issue with that is that I need to extract details from some regexp group. That’s where it starts to get messy .The middleware approach (Go) allows me to extract the fields and use an expression.
Yes, I am using a certificate generated with cert-manager (mounted as a volume). That works just fine.
For some context of what I am trying to do: I want to migrate from nginx in gitpod.io
And maybe this is just me but I tend to prefer to put the matchers right next to where they’re used, instead of all at the top. Reads more like code with this sort of structure:
condition1 = true
if condition1 {
return ...
condition2 = false
if condition2 {
return ...
return ...
