Regex help matching files in folders for status
I have this block and I’ve tried it a million ways, but the readme/changelog blocks never work.
I would like to block any readme.(html|md|txt) or changelog with same extension variants as 403.
here’s the latest attempt.
status 403 { /wp-config.php /wp-admin/install.php /wp-admin/includes/comment.php /wp-admin/network/menu.php /wp-admin/user/menu.php /wp-includes/admin-bar.php ~*((readme|changelog)\.(txt|html|md)) ~*readme.md ~*readme.html ~*changelog.html ~*changelog.md ~*changelog.txt }
I’m pulling my hair out at what should be easy –
It appears that the status block does not support regex yet?
Well, that stinks. :frowning:
See Deny access to to specific files - #4 by matt
You can cheat your way around that a little bit by using rewrites:
rewrite {
  r ^some-regex
  to /404
status 404 /404
Thanks to your reply on the other bad bot thread, I was able to piece that together. And, I even have a wordpress import file now… it’s running swimmingly.
Thanks for your help to me!
