I recently installed Sentry Self-Hosted on my server. The installation script create every Docker container at once, ready to be used.
In order to access it, the documentation indicates to install a reverse proxy in front of it.
Using the recommanded configuration for NGINX, and a Certbot configuration, it worked. I was able to access the website through https//sentry․example․com, and the workers installed using python module Sentry-SDK on my websites were able to communicate with Sentry.
I then discovered the power of Caddy, simplifying a lot my configurations to handle certificates and routes automatically.
I created the docker compose file that will power Caddy, and configured the Caddyfile as the Sentry documentation indicates (see 4.d).
When launched up, I was still able to access the website, but the workers were not able to communicate with Sentry anymore.
Caddy logs (debug mode), from docker compose -f caddy.yaml up (attached):
caddy | {"level":"debug","ts":1708445472.6647162,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"sentry-self-hosted-web-1:9000","duration":0.095230196,"request":{"remote_ip":"185.31.40.179","remote_port":"43910","client_ip":"185.31.40.179","proto":"HTTP/1.1","method":"POST","host":"sentry-self-hosted-web-1:9000","uri":"/api/6/envelope/","headers":{"User-Agent":["sentry.python/1.40.4"],"X-Forwarded-Host":["sentry․example․com"],"Content-Type":["application/x-sentry-envelope"],"X-Sentry-Auth":["Sentry sentry_key=REDACTED, sentry_version=7, sentry_client=sentry.python/1.40.4"],"X-Forwarded-Proto":["https"],"Content-Length":["4465"],"Accept-Encoding":["identity"],"Content-Encoding":["gzip"],"X-Forwarded-For":["185.31.40.179"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"http/1.1","server_name":"sentry․example․com"}},"headers":{"Content-Language":["en"],"Content-Length":["8519"],"X-Frame-Options":["deny"],"X-Content-Type-Options":["nosniff"],"X-Xss-Protection":["1; mode=block"],"Content-Security-Policy-Report-Only":["default-src 'none'; font-src 'self' data:; media-src *; script-src 'self' 'unsafe-inline' 'report-sample' 'nonce-BDKIaMz6vUYphEuFiWO7dg=='; frame-ancestors 'none'; object-src 'none'; img-src blob: data: *; base-uri 'none'; connect-src 'self' *․algolia․net *․algolianet․com *․algolia․io; style-src 'unsafe-inline' *"],"Content-Type":["text/html"],"Vary":["Accept-Language, Cookie"]},"status":403}
Django’s Sentry logs, from docker compose logs web -f :
web-1 | 16:10:50 [WARNING] django.security.csrf: Forbidden (Referer checking failed - no Referer.): /api/6/envelope/ (status_code=403 request=<WSGIRequest: POST '/api/6/envelope/'>)
From docker compose -f caddy.yaml exec caddy caddy version:
OS: Debian GNU/Linux 12 (bookworm)
CPU: Intel Xeon CPU E5-1620 v2 @ 3.70GHz x86_64
Docker: 25.0.3, build 4debf41
Docker compose: version v2.24.5
Running Sentry :
cd sentry-self-host
docker compose up -d
Running Caddy (after Sentry, so that the network exists):
docker compose -f caddy.yaml up -d
caddy.yaml
version: "3.8"
image: caddy:alpine
- caddy_data:/data
- caddy_config:/config
- 443:443
- caddy
- sentry-self-hosted_default
caddy_data:
caddy_config:
sentry-self-hosted_default:
driver: bridge
external: true
You can see here that I put Caddy in the same network that Sentry container created, in order for Caddy to be able to communicate.
I couldn’t get Sentry to use Caddy’s network (it broke Sentry), so I was forced to configure Caddy to use Sentry’s network.
Sentry configuration
sentry/config.yml:
system.url-prefix: 'https://sentry․example․com
system.internal-url-prefix: 'http://web:9000'
sentry/sentry.conf.py:
# SSL/TLS #
SECURE_PROXY_SSL_HEADER = ('HTTP_X_FORWARDED_PROTO', 'https')
USE_X_FORWARDED_HOST = True
SESSION_COOKIE_SECURE = True
CSRF_COOKIE_SECURE = True
SOCIAL_AUTH_REDIRECT_IS_HTTPS = True
As from the Sentry documentation:
sentry.example.com {
reverse_proxy sentry-self-hosted-web-1:9000 {
health_uri /_health/
health_status 2xx
tls contact@example.com
# Delete "Server" header
-Server
5. What I tried:
a. Referer header configuration
The error clearly indicates no Referer. I then tried to add the following instruction in the reverse_proxy section of my Caddyfile:
header_up Referer {header.Referer}
After that, the Referer Header was set up, but to an empty string, as if the header was not present before reaching Caddy, giving the following Django error: Referer is malformed
web-1 | 16:12:02 [WARNING] django.security.csrf: Forbidden (Referer checking failed - Referer is malformed.): /api/6/envelope/ (status_code=403 request=<WSGIRequest: POST '/api/6/envelope/'>)
b. No Sentry SSL configuration
I went up to my sentry/sentry.conf.py file to remove every SSL/TLS configuration, but nothing changed, it was as if nothing was edited (of course I restarted Sentry containers in order to apply the changes)
c. Django reqanalysis
Something that caught my eyes was that requests at route /api/<id>/envelope where failing, but the ones at /api/0/relays where working.
Looking at the Django code, it appears that the Referer header is checked only if the request is considered as secured (HTTPS).
And in fact, every request I make to Sentry has its request.is_secure() to False, except the ones coming from the Sentry workers.
Maybe that’s why it works using NGINX, but not with caddy: NGINX passes every request as HTTP (not secure). But Caddy documentation says the same:
transport defines how to communicate with the backend. Default is
http.
(remove space after https://)
https:// caddy.community/t/django-csrf-issues-with-reverse-proxy/16957
Note:
I know I shouldn’t redact the domains from the logs and configuration, but as this page will be indexed by search engines and is publicly accessible, I don’t want my domain to be find here. That’s why I replaced it with sentry․example․com everywhere, so that the logic is still there.
Also, I had to remove a lot of links that could have help you, but I’m limited to 4 as a new user…
Thanks in advance for any help you can bring me!
