Referencing already obtained Let's Encrypt wildcard cert elsewhere in Caddyfile "the right way"
I’m trying to set up reverse proxying for multiple hosts, some of them with client certificate authentication with certs from my own CA so I can give access to my friends. I want all hosts (mTLS or not) to present Let’s Encrypt wildcard certificates to users so they don’t have to install my CA’s certs. I don’t want to expose internal subdomains to the world by obtaining a subdomain-specific certificate for them.
My issue is that with my current config, Caddy doesn’t renew the certificate automatically when it expires. I assume this is because it knows the files are in use. If I delete the cert and key, Caddy just doesn’t start because it can’t find them. There must be a better way to reference the already obtained wildcard cert while also not “locking it”.
N/A
v2.11.3
Docker Compose on Linux
Raspberry Pi OS (Debian 11)
Docker-ce 29.1.3
N/A
    image: ghcr.io/caddybuilds/caddy-cloudflare:2
      CF_API_TOKEN: "${CF_API_TOKEN}"
    cap_add:
      - NET_ADMIN
      - "443:443/udp"
    dns:
      - 1.1.1.1
      - 1.0.0.1
      - $PWD/conf:/etc/caddy
      - /mnt/caddy/data:/data
# Global options
  # Disable HTTP to HTTPS redirects and handle them manually below in order to not leak Server headers
  auto_https disable_redirects
  cert_issuer acme {
    profile shortlived
# Snippet to disable sending the Server and Via headers
(disable_headers) {
  header -Server
  header -Via
http:// {
  import disable_headers
  redir * https://{host}{uri} 308
*.mydomain.tld {
  # Deny access from public IPs
  @denied not client_ip 192.168.11.0/24
  respond @denied 403 {
    close
  @grafana host grafana.mydomain.tld
  @zabbix host zabbix.mydomain.tld
  @adguard host adguard.mydomain.tld
  reverse_proxy @grafana 192.168.11.13:3002
  reverse_proxy @zabbix 192.168.11.10:8083
  reverse_proxy @adguard 192.168.11.10:8081
    protocols tls1.2 tls1.3
    dns cloudflare {env.CF_API_TOKEN}
    resolvers 1.1.1.1 1.0.0.1
    propagation_delay 1m
    propagation_timeout 5m
send.mydomain.tld {
  tls /data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/wildcard_.mydomain.tld/wildcard_.mydomain.tld.crt /data/caddy/certificates/acme-v02.api.letsencrypt.org-directory/wildcard_.mydomain.tld/wildcard_.mydomain.tld.key {
    client_auth {
      mode require_and_verify
      trust_pool file /etc/caddy/mydomain_tld_client_auth_ca_chain.pem
  reverse_proxy 192.168.11.10:50080
  log
matrix.mydomain.tld {
    client_auth {
  reverse_proxy 192.168.11.12:8448
  log
