Redirects for app running as subfolder behind proxy
I have an app (RStudio) running behind a proxy using Caddy. I map it to a subdirectory like so:
  proxy /rstudio rstudio:8787 {
    without /rstudio
    header_upstream Host {host}/rstudio
    websocket
  redir /rstudio /rstudio/ 307
(In this case Caddy and RStudio are running as separate docker images, so rstudio is the name of the Docker service)
However, when RStudio redirects the user, it sends them to the top top level, not pages under my.site/rstudio. So to log in, it redirects to my.site/auth-sign-in, not my.site/rstudio/auth-sign-in.
I attempted to fix this by adding another redirect:
  redir /auth-sign-in /rstudio/auth-sign-in 307
This works to get to the login page, but after I log in it then redirects to my.site/, not my.site/rstudio/. I attempted to use the referrer, like so
redir 307 {
 if {>Referrer} has /rstudio
 / /rstudio
This doesn’t seem to work. It may not recognize the referrer?
Apps that are reverse-proxied need to be able to support that; RStudio either doesn’t or isn’t configured to preserve the URI.
I think there’s an open issue requesting a feature so that proxy can rewrite redirect locations for situations where backends don’t support reverse proxying.
