ajfriesen
(Andrej Friesen)
January 4, 2022, 4:12pm
1
latest caddy:2 docker image
Docker on ubuntu host
version: '3'
image: caddy:2
- $PWD/blog/Caddyfile:/etc/caddy/Caddyfile
- caddy-data:/data
- docker-network
ghost:
image: ghost:4
restart: always
# see https://ghost.org/docs/config/#configuration-options
database__client: mysql
database__connection__host: db
database__connection__database: ghost
database__connection__user: ghost
database__connection__password: "${MYSQL_PASSWORD}"
# this url value is just an example, and is likely wrong for your environment!
url: https://www.ajfriesen.com
mail__transport: "${MAIL_TRANSPORT}"
mail__options__host: "${MAIL_HOST}"
mail__options__port: "${MAIL_PORT}"
mail__options__secureConnection: "${MAIL_SECURE_CONNECTION}"
mail__options__auth__user: "${MAIL_USER}"
mail__options__auth__pass: "${MAIL_PASSWORD}"
# Optional email key for lets encrypt
email my-mail
# Optional staging lets encrypt for testing. Comment out for production.
www.ajfriesen.com {
reverse_proxy ghost:2368
ajfriesen.com {
redir https://www.ajfriesen.com{uri}
www.andrej-friesen.com {
I am running a blog on my domain without any issues regarding caddy on www.ajfriesen.com
Now I wanted to add another domain I own www.andrej-friesen.com
I created a CNAME from www.andrej-friesen.com to ajfriesen.com but can not reach my site with that domain.
ping ajfriesen.com
PING ajfriesen.com (116.203.153.211) 56(84) bytes of data.
PING www.ajfriesen.com (116.203.153.211) 56(84) bytes of data.
64 bytes from static.211.153.203.116.clients.your-server.de (116.203.153.211): icmp_seq=1 ttl=52 time=19.1 ms
64 bytes from static.211.153.203.116.clients.your-server.de (116.203.153.211): icmp_seq=1 ttl=52 time=18.6 ms
curl -v www.andrej-friesen.com
* Trying 116.203.153.211:80...
* TCP_NODELAY set
* Connected to www.andrej-friesen.com (116.203.153.211) port 80 (#0)
> GET / HTTP/1.1
> Host: www.andrej-friesen.com
> User-Agent: curl/7.68.0
< Connection: close
< Location: https://www.andrej-friesen.com/
< Server: Caddy
< Date: Tue, 04 Jan 2022 15:59:35 GMT
< Content-Length: 0
* Closing connection 0
matt
(Matt Holt)
January 4, 2022, 4:14pm
2
That seems to be working fine, Caddy is responding to your requests. What is the problem exactly?
ajfriesen
(Andrej Friesen)
January 4, 2022, 4:30pm
3
Sorry, thought it was obvious
The blog is not available via www.andrej-friesen.com but is fine on www.ajfriesen.com
Are you certain you’re using the latest version?
Run docker-compose exec caddy caddy version to see the actual version number. Latest is v2.4.6 currently.
Are you sure you reloaded Caddy after making config changes? It seems like the server doesn’t have a certificate for www.andrej-friesen.com.
You can perform a graceful config reload by running docker-compose exec -w /etc/caddy caddy caddy reload
Check the container logs with docker-compose logs caddy, and make sure the logs show that Caddy loaded with the domain www.andrej-friesen.com listed in the log with the message "enabling automatic TLS certificate management"
matt
(Matt Holt)
January 4, 2022, 4:46pm
5
What do you mean by “not available” though? What indicates that? (You left numbers 4, 5, and 6 empty in the help template.) As far as I can tell everything is working fine. What happens when you follow the redirect?
ajfriesen
(Andrej Friesen)
January 4, 2022, 5:06pm
6
francislavoie:
I am managing the docker-compose files via ansible and was assuming that a change will restart the container. I could have sworn I had done that already because I added and removed domains over the last few months there.
My mistake, it does not do that automatically. Nothing caddy-related.
matt:
When I followed www.andrej-friesen.com I got Chrome saying ERR_SSLPROTOCOL_ERROR and not showing my blog.
That is what I mean by “redirect does not work”.
Now the reload is done everything works as expected.
So I got the config right in the first place but was fooled by my assumption of the autoreload for my ansible:
- name: "Create docker network"
docker_network:
- name: Sync blog
ansible.posix.synchronize:
src: blog/
dest: /home/andrej/blog
- name: Create and start docker services
community.docker.docker_compose:
project_src: /home/andrej/blog
state: present
restarted: yes # <------ Was missing this.
Again nothing caddy-related.
Mea Culpa!
matt
(Matt Holt)
January 4, 2022, 5:07pm
7
Excellent, thanks for the follow-up! Glad you figured it out.
system
(system)
Closed
February 3, 2022, 4:13pm
8
