Redirect with changed uri
I’m trying to find a way to redirect with changing uri on the fly.
It’s easy task:
site.com/old/__any_path
301 redirect to
archive.site.com/__any_path
hanlde_path and uri doesn’t help because they don’t redirect.
If use usual redirect than it gets uri and the result is:
archive.site.com/old/__some_path
Sorry if it already was questioned but I didn’t find clear answer about right way to do it.
You’ll want a path_regexp matcher here probably.
site.com {
	@old path_regexp old ^/old/(.*)
	redir @old https://archive.site.com/{re.old.1}{query} 301
Yep, it works. Thank you!
One small question — what is {re. Is it cut from ‘regexp’? Didn’t find it in the documentation
It’s a placeholder shortcut available in the Caddyfile. re is short for “regular expression”
Thanx! Very useful!
