2.4.6
Docker
Raspberrypi 4 + Debian 64bit
Actually I have the following configuration
Router - server - port 1
- port 2
- port 3
On every port I have different service running on my server.
I would like to know how it is possible to configure caddy in order to access the different services with a different subdirectory something like
http://myserver/subdir instead of http://myserver:theportoftheservice
myserver:443 {
root * /var/www/html/
reverse_proxy /subdir/* 192.168.1.10:theportoftheservice
tls /etc/caddy/SSL/cert1.pem /etc/caddy/SSL/privkey1.pem
it seems it is not working ![]()
If I try to connect to https://myserver/subdir
I get the following page
This is not the page you are looking for
The file /zigbee/ couldn’t be found.
See the Caddyfile part I’ve posted
