1. Output of caddy version:
Version 2.5.2
Under docker and listening on :80 and :443
Docker on debian
docker restart caddy
version: '3.9'
image: 'caddy:latest'
container_name: 'caddy'
restart: always
- '80:80'
- '443:443'
- './Caddyfile:/etc/caddy/Caddyfile'
- './caddy_config:/config'
- './caddy_data:/data'
- webgateway
webgateway:
external: true
glpi-test.example.fr {
reverse_proxy glpi
rewrite /plugins/fusioninventory/* /front/inventory.php
tls internal
The problem I’m having is that I have updated GLPI version to the latest but a lot devices (PDA) are pointing on the older link: http://glpi-test.exampl.fr/plugins/fusioninventory/. Now, I’m able to rewrite this url if this is in https but I can’t redirect the http…
I don’t have any error. It just doesn’t work.
I tried something like:
https://glpi-test.example.fr {
reverse_proxy glpi
tls internal
http://glpi-test.example.fr {
reverse_proxy glpi
Which works but it also enable http access for the site.
Sorry, if I’m not clear, I still have to learn a lot of things.
Thank you for your help !
edit:
BTW, I’m using Caddy only for reverse proxy.
I did this:
reverse_proxy glpi
rewrite /plugins/fusioninventory/ /front/inventory.php
tls internal
http://glpi-test.exampl.fr/plugins/fusioninventory/ {
reverse_proxy glpi
And now it works in http only on specific url but i don’t know if this is “clean”. Also, how can I get a valid certificate for https ?
