v2.5.2
I’m running Postman and calling a HTTP POST on:
http://vm.covergre.local:4905/api/login
vm.covergre.local is the host for a virtual machine, where Caddy Server is configured.
Ubuntu 20.04
caddy fmt --overwrite /etc/caddy/Caddyfile
cd /etc/caddy
caddy reload
handle :4905 {
handle_path /api/* {
redir http://cover-applqlt.covergre.local:8020/sysctl/zmpis{uri}?client=200
handle * {
reverse_proxy localhost:4903
The problem I’m having is that the redir is sending the HTTP request without a payload/body.
The purpose of this Caddy file is to send anything starting with /api/* to cover-applqlt.covergre.local and all other request to a different port on the same machine.
I’ve tried changing the redir to a reverse_proxy like this:
handle :4905 {
reverse_proxy cover-applqlt.covergre.local:8020/sysctl/zmpis{uri}?client=200 {
tls_insecure_skip_verify
handle * {
But I’m getting 502 Bad Gateway with error ‘missing port in address’. This is the log:
2022/07/15 14:19:50.289
DEBUG
http.handlers.rewrite
rewrote request
"request": {
"remote_ip": "172.16.222.141",
"remote_port": "58982",
"proto": "HTTP/1.1",
"method": "POST",
"host": "vm.covergre.local:4905",
"uri": "/api/login",
"headers": {
"Content-Length": [
"61"
"Content-Type": [
"application/json"
"User-Agent": [
"PostmanRuntime/7.29.0"
"Accept-Encoding": [
"gzip, deflate, br"
"Connection": [
"keep-alive"
"X-Authorization": [
"eyJhbGciOiJIUzUxMiIsInR5cCI6IkpXVCJ9.eyJ1c2VybmFtZSI6IkFETUlOIiwiaWF0IjoxNjU3MTE5MTgxLCJleHAiOjE2NTcxMTkyNDF9.k182k94KD2k1mukWDAC2xHQGhJxHiQZ9A43UTH388Fzy3xYCxFhemGAOOnHgmvgQbs5FnWibIF7O7tbjh4MK7Q"
"Accept": [
"Postman-Token": [
"7d2fbdeb-6109-4899-9777-6b79450dbdf8"
"method": "POST",
"uri": "/login"
ERROR
http.log.error.log0
making dial info:
upstream cover-applqlt.covergre.local:8020/sysctl/zmpis{http.request.uri}?client=200:
invalid dial address cover-applqlt.covergre.local:8020/sysctl/zmpis/login?client=200:
address sysctl/zmpis/login?client=200: missing port in address
"request": {
"method": "POST",
"headers": {
"Content-Length": [
"61"
"Content-Type": [
"application/json"
"User-Agent": [
"gzip, deflate, br"
"Connection": [
"keep-alive"
"Accept": [
"Postman-Token": [
"duration": 0.000159699,
"status": 502,
"err_id": "6uwx1v698",
"err_trace": "reverseproxy.statusError (reverseproxy.go:1184)"
Any help will be greatly appreciated.
Thank you!
