Windows 10.0.19042 Build 19042
.\caddy_windows_amd64.exe run --config Caddyfile
localhost:8443 {
reverse_proxy localhost:8096
I’m trying to make http://localhost:8443 redirect to https://localhost:8443, which is setup as a reverse proxy.
Client sent an HTTP request to an HTTPS server.
I tried to set a redir before the reverse proxy setting, like this:
http://localhost:8443 {
redir https://localhost:8443
https://localhost:8443 {
But then I get this message when trying to run caddy:
2021/01/07 15:38:51.176 INFO using provided configuration {“config_file”: “Caddyfile”, “config_adapter”: “”}
run: adapting config using caddyfile: server listening on [:8443] is configured for HTTP and cannot natively multiplex HTTP and HTTPS: https://localhost:8443
