Redir didn't work as expected. What should I do?
How do I redir to port 443 when I only have an https server running on port 8443?
I’m trying to make all requests to port :80 redir to :443. but none of them work except for some configurations. It just redir to 8443. What should I do?
None
v2.7.6
centos 6.8
	auto_https disable_redirects
	https_port 443
	servers 127.0.0.1:5000 {
		listener_wrappers {
			proxy_protocol
		protocols h1 h2 h2c h3
# dummy server, automatic certificate renewal needed. Blocked by firewall.
new.com:8443 {
	root * /usr/share/caddy
	redir https://new.com:443{uri} permanent # doesn't work, always redir to :8443
	#redir https://{host}:443{uri} # work
http://new.com:5000 {
	log
	bind 127.0.0.1
I’m not sure I follow.
Please show an example request with curl -v. Enable the debug global option and show your logs.
Thanks for your reply. It works fine now. And I will post the newest Caddyfile I use.
And I still have question about why it doesn‘t work before.
		listener_wrappers {
			proxy_protocol
sth.example.com:8443 {
	redir https://{host}{uri} permanent
http://sth.example.com:5000 {
	log
	bind 127.0.0.1
Why are you disabling redirects if you’re just re-adding them by hand? I don’t understand.
Servers located on port 5000 are not allowed to use https. then I was hoping that the auto https feature would work either way. I tried it and now it works, so I guess I better leave it alone :thinking:
For some reason, this problem no longer occurs. Even when I re-enabled the configuration that was previously considered problematic, and tested with curl, fiddler failed to reproduce the previous issue again. Thanks again for your reply!
Using http:// on your site address ensures that it uses HTTP. So there’s no need to touch auto_https for that reason.
I tried. And then it redir to 8443 port again.
# curl -v sth.example.com
* About to connect() to sth.example.com port 80 (#0)
*   Trying a.b.c.d...
* Connected to sth.example.com (a.b.c.d) port 80 (#0)
> GET / HTTP/1.1
> User-Agent: curl/7.29.0
> Host: sth.example.com
< Connection: close
< Location: https://sth.example.com:8443/
< Server: Caddy
< Date: Sun, 18 Feb 2024 17:14:08 GMT
< Content-Length: 0
* Closing connection 0
It happend again:
*   Trying a.b.c.d...
> GET / HTTP/1.1
< Connection: close
< Server: Caddy
< Content-Length: 0
I understand. For caddy’s auto https, the automatic redir to the first https enabled site is the default behavior. It doesn’t matter if that site’s port is 443. So I need:
and:
I’m confused. Why do you want it to redirect to 443? Caddy isn’t serving 443 with your current Caddyfile.
I forgot to add more background description, sorry. port 443 is occupied by other application. caddy only handles port 5000, port 80. port 8443 is used to spoof caddy to issue certificates for the whole site.
Why not just change the port of that app to something else, then have Caddy proxy to it? Much simpler if Caddy has ports 80+443, especially for solving ACME challenges.
I couldn’t find a way to properly configure that program, so I had to leave it on port 443. By the way, I accidentally gave away my site ip in a reply. Is there any way to remove it?
What program?
I hid it.
Thank a lot. Some kind of dashboard I guess? The network configuration seems to be hardcoded inside the program. I didn’t find anything about it in the documentation anyway.
Dashboard for what?
