Recently switched to Caddy. Some REST API clients send incorrect content-length headers. Can we ignore it somehow?
We have ancient IoT API clients that are sending incorrect content-length headers when performing an upload of a gzipped file.
If we use the following curl command, we can simulate what is happening:
curl -v \
http://local.redacted.com/api/v1/machine-info \
-H "Authorization: Basic redacted" \
-H "Content-Encoding: gzip" -H "Content-Type: application/gzip" -H "Content-Length: 123" \
--data-binary @uploaded-mac-info-20240329-204042.572958-redacted.gz
Removing the content-length header from the curl command works because curl calculates the size of the file correctly.
Logs are not relevant (I think) because the symptom is Flask not receiving a complete response from Caddy.
Docker containers running on ECS/Fargate
Docker
FROM caddy:2.7.6-builder-alpine AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/route53 \
    --with github.com/caddyserver/transform-encoder
RUN ls -l
RUN pwd
RUN find / -name Caddyfile
FROM caddy:2.7.6-alpine
RUN apk -U add curl
RUN --mount=type=bind,source=deploy,target=/deploy cp /deploy/caddy/Caddyfile /etc/caddy/Caddyfile
	default_sni {$FQDN}
	auto_https disable_redirects
		output stdout
		format transform `https {request>headers>X-Forwarded-For>[0]:request>remote_ip} - {user_id} [{ts}] "{request>method} {request>uri} {request>proto}" {status} {size} "{request>headers>Referer>[0]}" "{request>headers>User-Agent>[0]}"` {
			time_format "02/Jan/2006:15:04:05 -0700"
		level INFO
	admin 0.0.0.0:2019 {
	servers {
		trusted_proxies static private_ranges
		client_ip_headers X-Forwarded-For X-Real-IP
http:// {
		output stdout
		format transform `http {request>headers>X-Forwarded-For>[0]:request>remote_ip} - {user_id} [{ts}] "{request>method} {request>uri} {request>proto}" {status} {size} "{request>headers>Referer>[0]}" "{request>headers>User-Agent>[0]}"` {
		level INFO
	request_body {
		max_size 96MB
		reverse_proxy {$SERVICE}
{$FQDN} {
	request_body {
		max_size 1GB
		dns route53 {
		output stdout
		level INFO
	encode zstd gzip
Nevermind, this is Flask that’s doing this. Bypassing Caddy reveals the same result.
