Receiving response from simple load balancer inside a Docker container
1. Output of caddy version:
v2.6.1 h1:EDqo59TyYWhXQnfde93Mmv4FJfYe00dO60zMiEt+pzo=
Within a Docker container
Unix (AWS Linux 2 AMI)
See below for Docker run command
docker run \
    --log-driver=fluentd \
    --log-opt tag="cl.caddy" \
    --log-opt fluentd-address=localhost:24224 \
    --restart unless-stopped \
    -u ${DOCKER_USER_ID}:${DOCKER_GROUP_ID} \
    --name caddy \
    -p 8545:8545 \
    -p 8546:8546 \
    -p 50000:50000 \
    -p 50001:50001 \
    -v /lw/caddy:/caddy \
    -v /lw/caddy/Caddyfile:/etc/caddy/Caddyfile \
    -v /lw/caddy:/config/caddy/ \
    -v /lw/caddy:/data \
    -d caddy:2.6.1
http://rpc-internal:50000 {
	respond "internal worked!"
http://rpc-external:50001 {
	respond "external worked!"
http://rpc-balancer:8546 {
	reverse_proxy {
		to http://rpc-internal:50000 http://rpc-external:50001
		lb_policy first
		lb_try_duration 5s
		lb_try_interval 50ms
I’m trying to run a basic load balancer within Caddy that can proxy to two endpoints (rpc-internal, rpc-external).
“rpc-internal” will eventually be a local docker container, and “rpc-external” will be an external URL on the public internet, but I can’t even get this basic test case of returning a simple string (ie, “external worked!”) correct.
"wget localhost:50000" returns HTTP 200, empty response (expecting "internal worked!").
"wget localhost:50001" returns HTTP 200, empty response (expecting "external worked!").
"wget localhost:8546" returns HTTP 200, empty response (expecting "internal worked!" or "external worked!").
See above for the wget commands that I’ve tried. Thank you!!!
Hi :slight_smile:
hostnames/domains are an exact match, so essentially what’s happening is the following:
  • Your wget localhost:50000 sends a http request with Host: localhost:50000
  • Caddy checks if it is configured to serve anything on localhost:50000 but it only sees rpc-internal:50000
  • So Caddy couldn’t find a match and responds with the default, a blank http/200
You can see that in action when running wget --header "Host: rpc-internal:50000" localhost:50000 instead.
If you plan to use only a single vhost per port anyway, you could use http://:50000 instead of http://rpc-internal:50000
http://:50000 {
That’s basically a wildcard match for everything on that port :innocent:
