Hi,
I have some encrypted information in the domain name which needs to be case sensitive so that the server can decrypt it correctly. Is there any way to configure caddy so that it receives the domain name in a case sensitive fashion? For example, if the domain name is JZmi7Q7m0m1fVVEJDjtip2YhvyZz2w.example.com, I want to receive it as it is. Currently, I receive jzmi7q7m0m1fvvejdjtip2yhvyzz2w.example.com which is the case insensitive version and my decryption fails.
Domain names are case-insensitive by spec. This sounds a bit like an abuse of DNS… and I don’t think I would be fond of changing Caddy to support that.
You might be able to as a plugin, but don’t expect clients like browsers or curl to treat them the way you want, either. :-/
You could try using an encoding that is not case-sensitive, maybe?
I wonder if any of other web servers preserve case as received from the client?
Probably Tor servers?
