Reach parts of webapp based on presence of user-specified cookie
This is just a technical question as part of my research before doing anything.
I want to define a user specified cookie that is forwarded from client (user) to reverse proxy (caddy) in order to gain access to some parts of the webapp.
To be straight forward and avoid the XY problem, i am reinforcing my homelab so i am about to deploy Keycloak and expose it via proxy (instance in AWS) so clients (users) that use my services can log in via Keycloak instead of per-app authentication method. Setting up it like this has some vurneabilities like any user can potentially reach the admin panel (they may be refused because of not providing right credentials but still). I would like to restrict it using secret cookie or header (or some sort of additional key) to prevent them from reaching such places of Keycloak. I found module into Caddy that would select backend server based on cookie. Did someone set it up and could you maybe share the config with me so i can have better insight into how things are set?
None yet
caddy-cloudflare:2.8.4 (in docker container)
Running on Docker version 26.1.4, build 5650f9b via Portainer 2.27.0-rc3 LTS
version: '3.3'
    image: iarekylew00t/caddy-cloudflare:2.8.4
      - 443:443
      - /home/docker/docker_caddy/caddy:/etc/caddy
      - /home/docker/docker_caddy/site:/srv
      - /home/docker/docker_caddy/caddy_data:/data
      - /home/docker/docker_caddy/caddy_config:/config
      CLOUDFLARE_API_TOKEN: "REDACTED"
      - caddy
  email my_email@gmail.com
immich.dashrave.eu {
  reverse_proxy 10.19.3.29:5436
*.internal.dashrave.eu {
  @services host services.internal.dashrave.eu
  handle @services {
    reverse_proxy 10.19.3.29:1324
This is the module i found that can potentially help reaching what i need to do.
Not sure the scope of what you are doing, but I was able to use a cloudflare tunnel to provide authenticated access to my home network. Very slick.
Instructional: https://www.youtube.com/watch?v=ZvIdFs3M5ic&t=1676s
I found this post. That is basically what i needed. Now i just need to apply it only on some paths within the webapp.
