Is there any plan to get rate limiting into caddy v2 as a default module or external module? I can help with migration.
EDIT JUNE 2021: This topic is getting a lot of clicks in search results, so the updated answer is that I did make a rate limiting module:
Old answer:
There is no rate limiter planned yet that I know of, but I’d happily entertain a design disussion and proposal in our issue tracker! Sign in to GitHub · GitHub
(The actual module code will probably live in a separate repo though.)
thanks for the response. Do you think this design could be good enough as a design ref?
I think a proposal should start fresh with Caddy 2. You can use the v1 plugin for ideas, sure, but not much beyond that in the proposal/design phase. (Later—during development—similar logic in code could be brought over, of course.)
I’d start with describing the high-level functionality, what the module name would be, what its config structure would look like, what the behavior would be in various situations, and figure out the Caddyfile syntax last.
