I’m trying to run Kasm behind Caddy. By default, this application uses a self-signed certificate. I’m planning to let caddy handle the certificate and just proxy to Kasm running on the same machine (on port 8443).
According to their documentation there shouldn’t be much configuration required (annotation is mine):
local_certs # skipping this because i want caddy to create a cert
default_sni kasm.example.local
https://kasm.example.local:443 {
reverse_proxy https://127.0.0.1:8443 {
tls_insecure_skip_verify
header_up Host {host}
header_up X-Real-IP {remote}
header_up X-Forwarded-For {remote}
header_up X-Forwarded-Port {server_port}
When i load the application (you can try yourself), some requests randomly fail. There is no pattern to it but for each page loads there are a few.
The application is running fine without caddy and still works as expected when using SSH port forwarding to directly access it on port 8443.
Here is one of the failed requests:
# General
Request URL: https://kasm.pingbit.de/
Request Method: GET
Status Code: 502
Remote Address: 130.61.217.97:443
Referrer Policy: strict-origin-when-cross-origin
# Response headers
alt-svc: h3=":443"; ma=2592000
content-length: 0
date: Sun, 16 Apr 2023 20:37:21 GMT
server: Caddy
# Request HEaders
:authority: kasm.pingbit.de
:method: GET
:path: /
:scheme: https
accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
accept-encoding: gzip, deflate, br
accept-language: de-DE,de;q=0.9
cache-control: no-cache
dnt: 1
pragma: no-cache
sec-ch-ua: "Chromium";v="112", "Google Chrome";v="112", "Not:A-Brand";v="99"
sec-ch-ua-mobile: ?1
sec-ch-ua-platform: "Android"
sec-fetch-dest: document
sec-fetch-mode: navigate
sec-fetch-site: same-origin
sec-fetch-user: ?1
upgrade-insecure-requests: 1
user-agent: Mozilla/5.0 (Linux; Android 6.0; Nexus 5 Build/MRA58N) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Mobile Safari/537.36
While i found some similar threads abut seemingly related issues, most of them end up using tls_insecure_skip_verify
and carry on with their day.
I hope i’m not barking up the wrong tree. To me it seems like the request is not even getting trough to Kasm, that’s why i’m asking for help here Any help/pointer is appreciated.
Apr 16 20:36:30 bender caddy[553075]: {"level":"error","ts":1681677390.34172,"logger":"http.log.error.log0","msg":"tls: first record does not look like a TLS handshake","request"
More logs here: 0.g.gg .
Linux bender 5.15.106 #1-NixOS SMP Wed Apr 5 09:25:02 UTC 2023 aarch64 GNU/Linux
I don’t think it is relevant but anyways, i just enabled Caddy as a service in NixOS.
services.caddy.enable = true;
services.caddy.email = "<snip>;
services.caddy.globalConfig = ''
default_sni kasm.pingbit.de
cat /etc/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
ExecStart=/nix/store/y3f0ambxjqrr95jasdpi3b6dw7vnxxsd-caddy-2.6.4/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/nix/store/y3f0ambxjqrr95jasdpi3b6dw7vnxxsd-caddy-2.6.4/bin/caddy reload --config /etc/caddy/Caddyfile --force
PrivateDevices=yes
email <snip>
acme_ca https://acme-v02.api.letsencrypt.org/directory
level ERROR
https://kasm.pingbit.de:443 {
bind
output file /var/log/caddy/access-https://kasm.pingbit.de:443.log
reverse_proxy : https://127.0.0.1:8443 {
