Caddy v1.0.4 (h1:wwuGSkUHo6RZ3oMpeTt7J09WBB87X5o+IZN4dKehcQE=)
Windows 10 as a service
c:\caddy\caddy.exe -conf=c:\caddy\caddyfile -log=c:\caddy\logs\access.log
(mycommon)
ext .html .htm .php
root /caddy/www # Change path & syntax for your OS or your preferred location!
gzip
header / {
(mylocations)
proxy /sabnzb 127.0.0.1:8080 { # https://sabnzbd.org/
proxy /sonarr 127.0.0.1:8989 { # https://sonarr.tv/
proxy /sonarr4k 127.0.0.1:8990 { # https://sonarr.tv/
proxy /nzbhydra 127.0.0.1:5076 { # https://github.com/theotherp/nzbhydra
header_upstream X-Forwarded-Host {host}
rewrite / {
#Rewrite URLs without trailing slash
regexp ^/nzbhydra$
to /nzbhydra/
proxy /radarr 127.0.0.1:7878 { # https://github.com/Radarr/Radarr
proxy /radarr4k 127.0.0.1:7879 { # https://github.com/Radarr/Radarr
redir 301 {
if {>referer} is https://mydomain.org/bi
if {path} not_has bi/
/ /bi/{path}
proxy /bi 127.0.0.1:10882 {
without /bi
proxy / 127.0.0.1:9091 {
header_upstream X-Forwarded-Host {host}:9091
header_upstream -Origin
header_upstream -Referer
# web domain server block
https://mydomain.org:989
dns cloudflare
# New log directive syntax for v0.10.x
log /caddy/logs/access.log { # Change path syntax for your OS or your preferred location!
rotate_size 1 # Rotate after 1 MB
rotate_age 7 # Keep log files for 7 days
rotate_keep 2 # Keep at most 2 log files
errors visible
errors /caddy/logs/error.log { # Change path syntax for your OS or your preferred location!
rotate_size 1 # Set max size 1 MB
import mycommon # Import code snippet 1 defined above
import mylocations # Import code snippet 2 defined above
localhost:990 192.168.1.100:990
Radarr, a program that I’m using is not working properly. According to their wiki, when people are running a reverse proxy, they need to add some things to make it work.
Specifically, they say when using nginx, to add the following:
proxy_http_version 1.1;
proxy_set_header Connection $http_connection;
Chrome console error is here. I don’t see anything in the caddy logs, but not sure if I should be?
I tried asking in their support discord server, but nobody appears to know. They asked me to ask Caddy people for help and update their wiki page ![]()
