Radarr/sonarr etc.. without base url
2.1.1 docker builder with webdav, http.filter and cloudflare dns module
Running using docker/docker-compose, from a Caddy builder image.
     reverse_proxy 192.168.1.50:81
     handle_path /radarr/* {
     reverse_proxy 192.168.1.50:7878
I’ve tried a lot of combinations, but all I get is a blank page that says "Radarr Ver. "
I’d like to avoid a “base url” for radarr and other apps, i was using letsencrypt with the default configuration provided before.
no problem with subdomain but i prefer subfolder for my new config
radarr.domain.com {
There’s not enough information here. What exactly is the problem? Do you have any logs to show the issue?
Generally, I recommend using subdomains because it’s cleaner. If you need local access, you can do something like radarr.domain.com, :8081 { to listen on another port for local access.
But if you must use a subpath instead, then you need to configure a UrlBase in Radarr I think:
Sounds like a chronic case of the subfolder problem.
You can’t put your app in a subfolder without setting the base URL. The base URL must match the subfolder. This is required for asset links to line up. Explained further in this wiki post:
