Quic Protocol isn't working
Quic Protocol should work automatically with Caddy. But for some reason it’s not working for my wesbite. There is no issue with my network or browser.
There is no error message in the log. (Log that shows up after running systemctl status caddy
OS : Ubuntu 22.04.2 LTS (GNU/Linux 5.19.0-1025-aws x86_64)
Installed following this guide : Install — Caddy Documentation
Not applicable
nixorigin.one, www.nixorigin.one {
        root * /var/www/html/public
                X-Frame-Options "SAMEORIGIN"
                Referrer-Policy "same-origin"
        php_fastcgi unix//run/php/php8.1-fpm.sock
        # php_fastcgi localhost:9000
QUIC and HTTP/3 are over UDP, instead of TCP. Make sure your firewall and router allows UDP traffic on port 443. If you have ufw running on Ubuntu, check that it allows UDP traffic.
Thanks for the heads up. I’ve now allowed UDP traffic on my firewall. According to https://http3check.net/ QUIC is now working . But Tools search result saying the opposite. Is there any other way I can confirm this ? My browsers are still showing TLS 1.3 …
Never heard of that second site, and it looks broken (all the HTTP/3-enabled sites I try says it can’t connect).
The best way to confirm HTTP/3 is to use a curl build that supports HTTP/3 like so:
$ curl3 --http3 -v ...
This works for me now:
docker run -it --rm ymuski/curl-http3 curl -vs -D/dev/stdout -o/dev/null --http3 https://nixorigin.one
So you seem good to go :+1:
Yes, TLS 1.3 is the latest version of TLS. HTTPS is HTTP over TLS, and HTTP/3 always enables TLS. That’s correct and a good thing.
Thank you :blush:
