I run caddy as docker swarm reverse proxy: GitHub - lucaslorentz/caddy-docker-proxy: Caddy as a reverse proxy for Docker
RancherOS v1.5.6, Docker CE 19.03.5, lucaslorentz/caddy-docker-proxy:2.3.0
I use caddy as docker swarm reverse proxy and it works fine!
Now I tested tls client_auth and it works too. I used an existing eToken and configured tls client auth.
caddy.tls.client_auth.mode: "require"
caddy.tls.client_auth.trusted_ca_cert_file: "/data/nwe/nwe-ca.cert"
Generated caddy config:
client_auth {
mode require
trusted_ca_cert_file /data/nwe/nwe-ca.cert
If tls client auth fails (for example can’t be verified), there is a log entry, but in mode “require” (without verify) tls client auth is successful, but not logged?
- Is it possible to require a specified client / user certificate instead of just any client certificate?
- How to add the used client certificate to caddy log and http headers?
