origin
(Ben Heynow)
January 11, 2021, 8:42pm
1
Thanks so much for taking the time to read my post and thanks for any help you give!
Caddy v2 (v2.2.1)
I’m running Caddy with elevated windows command prompt
Windows 10 20H2
caddy.exe start
caddy.exe stop
NA (I think)
myddns.com:80 {
respond ":-P" 403
myddns:443 {
respond ":-P" 403
myddns.com:9100 {
reverse_proxy 127.0.0.1:8096
myddns.com:10500 {
reverse_proxy 127.0.0.1:10000 {
header_up X-Forwarded-Host {host}:10500
header_up -Origin
header_up -Referer
I am trying (and failing) to hook up qbittorrent’s WEBUI with a reverse proxy via caddy v2.
NA
I have forwarded port 10500 to 10000 on the server running qbittorrent; I’ve also setup the WEBUI to use port 10000.
I’ve tried to hack together a v2 caddyfile for this, using caddy v1 files as a base (e.g. Reverse Proxy With QBittorrent Web UI ) and trying to update the language so its v2 compliant.
The relevant bit in my caddyfile is:
myddns.com:10500 {
header_up -Origin
header_up -Referer
Trying to access the WEBUI with
https://myddns.com:10000
then I reach a webpage that says ‘Unauthorized’ and nothing else.
I can confirm that I am able to reach the qbittorrent WEBUI with
192.168.1.67:10000
I’m trying to setup a reverse proxy to access the QBittorrent web UI. I found this post on the forums: qBittorrent Web UI -- Reverse Proxy Help - #2 by Whitestrake but I still can’t get it to work.
This is what I have in my Caddyfile:
localhost:4488, 192.168.1.205:4488 {
proxy / 127.0.0.1:9292 {
header_upstream X-Forwarded-Host {host}:9292
header_upstream Origin ''
header_upstream Referer ''
It returns an 502 Bad Gateway error when I attempt to go to localhost:4488
The following …
You can actually use {hostport} in Caddy v2. But I’m not why this would be necessary
Maybe you can try to add header_up Host 127.0.0.1:10000 as well, since the Host header in Caddy v2 is inherited from the original request.
Either way, if that doesn’t fix it, I can try myself tonight on my Windows machine.
origin
(Ben Heynow)
January 11, 2021, 8:55pm
3
Amazing!
totally worked!
I’ve also taken your other suggestion on board and my caddyfile snippet now works like this:
myddns:10500 {
header_up X-Forwarded-Host {host}:{hostport}
header_up -Origin
header_up -Referer
Thank you so much!
You misunderstood, that should be just {hostport}, because {hostport} is the host plus the port, already.
Glad it worked!
origin
(Ben Heynow)
January 11, 2021, 9:01pm
5
Oops. Thanks for catching my mistake.
So, just for completeness x2 (in case any one is stuck in the future) my caddyfile looks like this
myddns:10500 {
header_up X-Forwarded-Host {hostport}
header_up -Origin
header_up -Referer
Thanks again!
