Malakan
(Malakan)
January 14, 2025, 4:15pm
1
I am trying to request an access token from one of my containers through python. Using a curl command in the terminal works, I get a data return and caddy logs but using python I get a 403 error in the Python terminal and zero caddy logs.
I have changed the url to avoid the need of credentials but the same errors occur regardless, data is returned with a curl command but not in Python (403 error).
In Python:
HTTP Error: 403 Forbidden
In Caddy: No logs produced
through a docker-compose file
Ubuntu 24.04 LTS. Docker-Compose
curl -X POST https://gramps.malakan.co.uk
import json
from urllib.error import HTTPError, URLError
from urllib.request import Request, urlopen
url = "https://gramps.malakan.co.uk"
req = Request(url)
try:
with urlopen(req) as response:
# Read the response
response_data = response.read().decode("utf-8")
print(f"Response: {response_data}")
except HTTPError as e:
print(f"HTTP Error: {e.code} {e.reason}")
except URLError as e:
print(f"URL Error: {e.reason}")
docker-compose.yml
include:
- ./helloworld.yml
- ./gramps.yml
caddy_net:
external: false
image: caddy
caddy_net:
- ./caddy/data/:/data/
- ./caddy/config/:/config/
gramps.yml
grampsweb: &grampsweb
container_name: grampsweb_server
image: ghcr.io/gramps-project/grampsweb:latest
restart: always
environment: &grampsweb-env
GRAMPSWEB_TREE: "Gramps Web" # will create a new tree if not exists
VIRTUAL_PORT: "5000"
VIRTUAL_HOST: gramps.malakan.co.uk # e.g. gramps.mydomain.com
GRAMPSWEB_CELERY_CONFIG__broker_url: "redis://grampsweb_redis:6379/0"
GRAMPSWEB_CELERY_CONFIG__result_backend: "redis://grampsweb_redis:6379/0"
GRAMPSWEB_RATELIMIT_STORAGE_URI: redis://grampsweb_redis:6379/1
depends_on:
- grampsweb_redis
- gramps_users:/app/users # persist user database
- gramps_index:/app/indexdir # persist search index
- gramps_thumb_cache:/app/thumbnail_cache # persist thumbnails
- gramps_cache:/app/cache # persist export and report caches
- gramps_secret:/app/secret # persist flask secret
- gramps_db:/root/.gramps/grampsdb # persist Gramps database
- gramps_media:/app/media # persist media files
- gramps_tmp:/tmp
caddy_net:
grampsweb_net:
grampsweb_celery:
<<: *grampsweb # YAML merge key copying the entire grampsweb service config
ports: []
container_name: grampsweb_celery
depends_on:
- grampsweb_redis
command: celery -A gramps_webapi.celery worker --loglevel=INFO --concurrency=2
grampsweb_net:
grampsweb_redis:
image: docker.io/library/redis:7.2.4-alpine
container_name: grampsweb_redis
restart: always
grampsweb_net:
grampsweb_net:
external: false
gramps_users:
gramps_index:
gramps_thumb_cache:
gramps_cache:
gramps_secret:
gramps_db:
gramps_media:
gramps_tmp:
malakan.co.uk {
reverse_proxy http://helloworld:8000
gramps.malakan.co.uk {
reverse_proxy http://grampsweb:5000
format json
level ERROR
test.malakan.co.uk {
format json
level INFO
@restricted path /restricted/*
respond @restricted 403
Hi @Malakan ,
And as a test can you change the URL to use HTTP and not HTTPS?
Trying to rule out TLS (SSL) issues such as TLS versions and cipher suite differences between curl and python.
Malakan
(Malakan)
January 14, 2025, 8:10pm
3
curl -X POST http://gramps.malakan.co.uk
seemingly has no return but does produce a log entries:
caddy | {“level”:“info”,“ts”:1736939369.2940955,“logger”:“http.log.access”,“msg”:“handled request”,“request”:{“remote_ip”:“141.101.98.153”,“remote_port”:“43786”,“client_ip”:“141.101.98.153”,“proto”:“HTTP/1.1”,“method”:“POST”,“host”:“gramps.malakan.co.uk ”,“uri”:“/”,“headers”:{“Accept-Encoding”:[“gzip”],“Cf-Visitor”:[“{"scheme":"http"}”],“X-Forwarded-Proto”:[“http”],“Cf-Connecting-Ip”:[“212.127.0.96”],“Connection”:[“Keep-Alive”],“Cf-Ray”:[“902569f1bb8c48cd-LHR”],“X-Forwarded-For”:[“212.127.0.96”],“Cdn-Loop”:[“cloudflare; loops=1”],“Accept”:[“/ ”],“Cf-Ipcountry”:[“GB”],“User-Agent”:[“curl/7.81.0”]}},“bytes_read”:0,“user_id”:“”,“duration”:0.000036595,“size”:0,“status”:308,“resp_headers”:{“Server”:[“Caddy”],“Connection”:[“close”],“Location”:[“Gramps Web ”: }}
For whatever reason this does seem to hang sometimes but canceling and rerunning always runs.
In python, using the below url, I still get the 403 error and no caddy logs
url = "http://gramps.malakan.co.uk"
The python script seems to error out at the below line:
At this point kindly wait for a more knowledgeable community member to assist.
matt
(Matt Holt)
January 15, 2025, 5:59pm
5
The request isn’t even hitting Caddy… it’s hitting Cloudflare, but it’s not showing Caddy. Especially if there’s no Caddy logs at all. So, maybe check your DNS settings / network configuration.
Malakan
(Malakan)
January 16, 2025, 7:14am
6
Looking at my cloudflare settings: I have A records for all DNS addresses, including gramps.malakan.co.uk . They are proxied and TTL is set to auto. SSL/TLS encryption mode is set to Full (strict).
As this is self-hosted, my router has all 80 and 443 traffic pointing to the server for internal and external ports for TCP/UDP.
Are there any other DNS settings / network configurations I need to look into?
Edit:
The issue appears to be the proxied setting on Cloudflare, disabling allowed the python script to get a server response.
both http and https had the same server response:
Response: <!doctype html><html lang="en"><head><meta charset="utf-8"><meta name="viewport" content="width=device-width,initial-scale=1,viewport-fit=cover"><meta name="description" content="Gramps Web - research & organize your family tree together"><base href="/"><link
rel="stylesheet" href="fonts/fonts.css"><link rel="stylesheet" href="tippy.css"><link rel="icon" href="images/favicon.ico"><link rel="manifest" href="manifest.json" crossorigin="use-credentials"><meta name="theme-color" content="#6D4C41"><meta name="mobile-web-app-capable"
content="yes"><meta name="application-name" content="Gramps"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-status-bar" content="#6D4C41"><meta name="apple-mobile-web-app-title" content="Gramps"><link rel="apple-touch-icon" sizes="192x192" href="images/icon192.png"><style>body,html{margin:0;padding:0;height:100%}</style><title>Gramps Web</title><link rel="preload" href="./2ea051d6.js" as="script" crossorigin="anonymous"></head><body><gramps-js></gramps-js><script src="config.js"></script><script type="module" src="./2ea051d6.js"></script><script>"serviceWorker"in navigator&&window.addEventListener("load",(function(){navigator.serviceWorker.register("sw.js").then((function(){console.log("ServiceWorker registered.")})).catch((function(e){console.log("ServiceWorker registration failed: ",e)}))}))</script></body></html>
Edit:
While the simple http/https url (gramps.malakan.co.uk ) gets a response, I now get a new error from my desired url: gramps.malakan.co.uk/api/token .
HTTP Error: 308 Permanent Redirect
One step closer to the solution!
This url requires some extra data to be sent, but here is the code I use with the password removed:
url = "http://malakan.co.uk/api/token"
data = {
"username": "Malakan",
"password": "[REDACTED]"
json_data = json.dumps(data).encode("utf-8")
headers = {"content-Type": "application/json"}
req = Request(url, data=json_data, headers=headers)
try:
# Read the response
Malakan
(Malakan)
January 16, 2025, 4:14pm
7
I’ve just tested it within the application I am trying to run and it works successfully now with the proxy setting off. Still get the 308 error with my own test python script…
Mohammed90
(Mohammed Al Sahaf)
January 16, 2025, 8:04pm
8
308 is not an error. It’s a redirection status telling the client to try at the URL specified in the Location header
Malakan:
get the 308 error
Use https
Malakan
(Malakan)
January 17, 2025, 6:39pm
9
I was also missing a / on the end of the url.
Going a google search, I found some info about headers. Setting my headers to below appears to solve the 308 and I can get my token in my Python script with the proxy OFF, how can I get this working with it ON?
headers = {
"User-Agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36",
"Content-Type": "application/json"
system
(system)
Closed
February 16, 2025, 6:40pm
10
