Hey Guys,
im trying to proxy transmission. I keep getting a connection failed error.
Visiting 10.0.0.2/bullshit/web/ directly works as intended. While searching for a solution i only found nginx configs, which simply use proxypass and proxypassrevers. The error leaves no trace in the transmission log.
Im hosting transmission on ubuntu xenial using transmission-daemon version 2.84 (14307)
My current config looks like this. Everything i uncommented didn’t change the outcome:
basicauth "XXXX" XXXXX {
/test/transmission
proxy /test/transmission 10.0.0.2/bullshit/web/ {
without /test/transmission
# websocket
# keepalive 0
# header_upstream X-Transmission-Session-Id hpUJUDunPasgl7kU3JUmO6YOsrp61v9HHZh23JDxeEDHtWSK
# header_upstream X-Transmission-Session-Id "<X-Transmission-Session-Id"
Caddy Log:
Feb 14 17:13:05 Trans/Host caddy[9490]: MY.IP.0.0 - - [14/Feb/2019:17:13:05 +0100] "POST /test/rpc HTTP/2.0" 404 14
Feb 14 17:13:05 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:05 +0100] "GET /test/transmission/style/transmission/images/settings.png HTTP/2.0" 200 201
Feb 14 17:13:05 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:05 +0100] "GET /test/transmission/style/transmission/images/logo.png HTTP/2.0" 200 5459
Feb 14 17:13:05 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:05 +0100] "GET /test/transmission/images/favicon.png HTTP/2.0" 200 706
Feb 14 17:13:07 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:07 +0100] "GET /test/transmission/ HTTP/2.0" 200 4333
Feb 14 17:13:08 Trans/Host caddy[9490]: MY.IP.0.0 - - [14/Feb/2019:17:13:08 +0100] "POST /test/rpc HTTP/2.0" 404 14
Feb 14 17:13:08 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:08 +0100] "GET /test/transmission/images/favicon.png HTTP/2.0" 200 706
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/ HTTP/2.0" 200 4333
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/jquery/jquery.min.js HTTP/2.0" 200 33617
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/jquery/jquery.contextmenu.min.js HTTP/2.0" 200 1018
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/jquery/json2.min.js HTTP/2.0" 200 1285
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/formatter.js HTTP/2.0" 200 2196
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/jquery/jquery.transmenu.min.js HTTP/2.0" 200 1745
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/dialog.js HTTP/2.0" 200 905
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/torrent-row.js HTTP/2.0" 200 2803
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/remote.js HTTP/2.0" 200 2118
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/notifications.js HTTP/2.0" 200 496
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/style/jqueryui/jqueryui-1.8.16.css HTTP/2.0" 200 5940
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/style/transmission/common.css HTTP/2.0" 200 5862
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/jquery/jqueryui-1.8.16.min.js HTTP/2.0" 200 51916
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/common.js HTTP/2.0" 200 3656
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/torrent.js HTTP/2.0" 200 3500
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/prefs-dialog.js HTTP/2.0" 200 2409
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/file-row.js HTTP/2.0" 200 1549
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/inspector.js HTTP/2.0" 200 5858
Feb 14 17:13:10 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:10 +0100] "GET /test/transmission/javascript/transmission.js HTTP/2.0" 200 11357
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/mobile.css HTTP/2.0" 200 4930
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/toolbar-folder.png HTTP/2.0" 200 1760
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/toolbar-close.png HTTP/2.0" 200 1525
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/toolbar-start.png HTTP/2.0" 200 1100
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/toolbar-pause.png HTTP/2.0" 200 700
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/toolbar-start-all.png HTTP/2.0" 200 1576
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/toolbar-pause-all.png HTTP/2.0" 200 935
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/toolbar-info.png HTTP/2.0" 200 1499
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/arrow-down.png HTTP/2.0" 200 154
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/arrow-up.png HTTP/2.0" 200 153
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/wrench.png HTTP/2.0" 200 242
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/turtle.png HTTP/2.0" 200 203
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/compact.png HTTP/2.0" 200 148
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/jqueryui/images/ui-bg_flat_75_ffffff_40x100.png HTTP/2.0" 200 87
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/jqueryui/images/ui-bg_highlight-soft_75_cccccc_1x100.png HTTP/2.0" 200 99
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/jqueryui/images/ui-bg_glass_65_ffffff_1x400.png HTTP/2.0" 200 95
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/jqueryui/images/ui-bg_glass_75_e6e6e6_1x400.png HTTP/2.0" 200 102
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/jqueryui/images/ui-icons_222222_256x240.png HTTP/2.0" 200 3473
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - - [14/Feb/2019:17:13:11 +0100] "POST /test/rpc HTTP/2.0" 404 14
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/settings.png HTTP/2.0" 200 201
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/style/transmission/images/logo.png HTTP/2.0" 200 5459
Feb 14 17:13:11 Trans/Host caddy[9490]: MY.IP.0.0 - AuthUser [14/Feb/2019:17:13:11 +0100] "GET /test/transmission/images/favicon.png HTTP/2.0" 200 706
Caddy Log when the error message is displayed:
Feb 14 17:16:49 Trans/Host caddy[9490]: MY.IP.0.0 - - [14/Feb/2019:17:16:49 +0100] “POST /test/rpc HTTP/2.0” 404 14
Feb 14 17:17:00 Trans/Host caddy[9490]: MY.IP.0.0 - - [14/Feb/2019:17:17:00 +0100] “POST /test/rpc HTTP/2.0” 404 14
