Proxying IP address with path
I need to reverse_proxy 192.168.0.197/path/file → example.domain.com/file
, but whatever I do I keep getting example.domain.com/path/file
I am not getting any errors
v2.8.1 h1:UVWB6J5f/GwHPyvdTrm0uM7YhfaWb4Ztdrp/z6ROHsM=
I installed stable caddy through the instructions on the official website for ubuntu
Ubuntu running on a Proxmox CT with systemd
ded.example.com {
        reverse_proxy /ded/* 192.168.0.197
I also tried
ded.example.com {
        reverse_proxy 192.168.0.197/ded
Solution!
On the 192.168.0.197 server, installed caddy, and ran each of the directories under its own port.
192.168.0.197/website-1 -> 192.168.0.197:8001
192.168.0.197/website-6 -> 192.168.0.197:8006
Which made it much easier to then proxy the websites within a separate container.
Sounds like you were looking for handle_path. But keep in mind this article:
