no error
v2.5.2
Docker with custom build
ARG CADDY_VERSION=latest
#FROM caddy:${CADDY_VERSION}-builder AS builder
FROM caddy:builder-alpine AS builder
RUN xcaddy build --with github.com/caddy-dns/cloudflare --with github.com/lucaslorentz/caddy-docker-proxy/v2
FROM caddy:alpine
#FROM caddy:${CADDY_VERSION}-alpine
CMD ["caddy", "docker-proxy"]
Docker debian
n/a
admin :2019
# enable Prometheus metrics endpoint https://caddyserver.com/docs/metrics
*.internal.domain {
tls letsencrypt-{$CADDYHOST}@domain {
dns cloudflare {$CLOUDFLARE_API_KEY}
log
@admin host admin-{$CADDYHOST}.internal.domain
handle @admin {
reverse_proxy localhost:2019
metrics {
disable_openmetrics
When I curl the caddy host (drogo = eg https://admin-drogo.internal.domain) I do get a response:
promhttp_metric_handler_requests_in_flight 1
# HELP promhttp_metric_handler_requests_total Total number of scrapes by HTTP status code.
# TYPE promhttp_metric_handler_requests_total counter
promhttp_metric_handler_requests_total{code="200"} 30
promhttp_metric_handler_requests_total{code="500"} 0
promhttp_metric_handler_requests_total{code="503"} 0
Hundreds of lines like that.
But when I curl for the config: https://admin-drogo.internal.domain/config, I believe I’m supposed to get the runnig config, but all I get are the metrics again.
What have I done wrong in my caddy file.
Also with the caddy file I have, it should be listening on everything. WHen if I look at the running config I see "admin":{"listen":"tcp/localhost:2019"}
I’m not too worried about that if I can get the reverse proxying to work (mine is all internal access, nothing is exposed directly.)
