Proxy works for root of domain
(Read this, then delete it before you post.) To get the best help possible, please:
  • explain what you are trying to do,
    I am trying to consolidate my outside presence by using Caddy as a front end proxy to the WAN/. For example my plex server which runs on port 32400 on the localhost. I tried this in my caddyfile:
    proxy /plex localhost:32400 {
But it gives me a 401 Unauthorized.
If I change the /plex to be / it will work perfectly. Any thoughts? I’m also trying to do the same with my home cameras which would be /cam1 and /cam2 but they give the same 401 Unauthorized errors unless they are the root.
Thanks again for any help!
Is plex expecting the path to have /plex in it? If not, use without /plex to strip it.
Thank’s for your help Matt. The link that is accessible (without a proxy) is http://localhost:32400/web/index.html
If localhost:32400 is visited it will redirect to /web/index.html which it does it i visit mydomain.com (proxy the root folder / ) but if I do a proxy for mydomain.com/plex it gives me the 401 error.
Plex is a bit of a problem when it comes to reverse proxying, exponentially so when it comes to subfolders instead of subdomains. I cannot recommend enough just putting it on a subdomain instead. It wants /web, /system, /servers, /accounts, /myplex, /photo, and /clients, as far as I’m aware.
That said, here is a very pertinent guide which covers using nginx for this purpose, the approach should be the same for Caddy with some config reverse engineering.
