sguiheux
(Guiheux Steven)
#1
Hello,
I’m trying to use “proxy” like this:
:2015 {
ext .html
gzip
log / stdout
proxy /api host:port/foo {
without /api
I want to call localhost:2015/api/bar and going to host:port/foo/bar but I am going to host:port/foo/api/bar
I am doing something wrong?
Regards
Steven
tobya
(Toby Allen)
#2
It works fine for me with your caddyfile
What version of caddy are you using?
sguiheux
(Guiheux Steven)
#4
My test:
curl -X GET http://127.0.0.1:2015/api/bar
Caddy log:
02/Dec/2016:21:54:14 +0100 [ERROR 502 /foo/api/bar] dial tcp 8.8.8.8:8081: i/o timeout
127.0.0.1 - [02/Dec/2016:21:54:14 +0100] “GET /foo/api/bar HTTP/1.1” 502 16
tobya
(Toby Allen)
#5
ok I see the issue. There is something going on .
So you want to raise it as an issue on github
github.com/mholt/caddy
sguiheux
(Guiheux Steven)
#6
system
(system)
closed
#7
