Proxy docker registry from nexus
1. Caddy version (caddy version): v2.4.6 h1:HGkGICFGvyrodcqOOclHKfvJC0qTU7vny/7FhYp9hNw=
Ubuntu 20.04
caddy validate
(letls) {
		resolvers ns1.digitalocean.com ns2.digitalocean.com ns3.digitalocean.com
		dns digitalocean <apikey>
nexus.evva.link {
	rewrite / /nexus
	reverse_proxy http://10.64.192.106:8081 {
        reverse_proxy /v2 {
                to http://10.64.192.106:18082/repository/evva-docker-group/{request_uri}
	import letls
We use nexus3 as an artifact repository. There are also the docker registries. I want to proxy them so we dont need to use the port. There is an example for nginx but I am not able to get it to work for caddy.
Error during parsing: due to parsing difficulties, placeholders are not allowed when an upstream address contains a scheme
Path matching is exact in Caddy v2. This will only match requests to /v2 and nothing else, i.e. it won’t match /v2/foo.
You can’t specify a path in reverse_proxy to perform a rewrite.
If you need to add a path prefix, use the rewrite directive to do so.
This option doesn’t exist in Caddy v2. It was a thing in Caddy v1, but it’s the default behaviour how in v2.
Ok it was not that complex as I thought.
Thats it I just created a new section and it works like a charm =)
On the nexus itself I configured a docker group that got all our docker-repos and the docker-hub (proxy) in it on port http 18082 if somebody needs that setup too =)
We only use http because we have a software defined network where all the caddy proxy stuff is running.
      docker.evva.link {
        reverse_proxy http://10.64.192.106:18082 {
        import letls
Another option would be:
nexus.evva.link {
	rewrite / /nexus
        reverse_proxy /v2/* http://10.64.192.106:18082 {
	import letls
Are you sure you need these, btw?
This will set the Host header to 10.64.192.106:8081.
Usually, the default behaviour of passing through the Host as-is, is what you want. These headers are typically only needed if you’re proxying to your upstream over HTTPS, as noted here:
