The following is written in version 1 configuration:
proxy /pluto https://pluto.web.telegram.org {
without /pluto
proxy /venus https://venus.web.telegram.org {
without /venus
Request assistance in rewriting to version 2
Thx
without /pluto
without /venus
Thx
Hi Arti, welcome back –
Our upgrade guide should help you out: Upgrading to Caddy 2 — Caddy Documentation
Hi,
I tried it, and I did the following.
route /venus/* {
uri strip_prefix /venus
reverse_proxy https://venus.web.telegram.org
route /pluto/* {
uri strip_prefix /pluto
reverse_proxy https://pluto.web.telegram.org
but it doesn’t work.
What didn’t work? We can’t help unless you’re more specific about the issues you’re encountering.
Version 1 with configuration:
webogram.choodique.me {
root /home/choo/apps/caddy/webogram/www
log /home/choo/apps/caddy/webogram/logs/webogram.log
errors /home/choo/apps/caddy/webogram/logs/webogram.err
header / {
X-Frame-Options "sameorigin"
without /pluto
without /venus
proxy /aurora https://aurora.web.telegram.org {
without /aurora
proxy /vesta https://vesta.web.telegram.org {
without /vesta
without /vesta
proxy /flora https://flora.web.telegram.org {
without /flora
proxy /pluto-1 https://pluto-1.web.telegram.org {
without /pluto-1
proxy /venus-1 https://venus-1.web.telegram.org {
without /venus-1
proxy /aurora-1 https://aurora-1.web.telegram.org {
without /aurora-1
proxy /vesta-1 https://vesta-1.web.telegram.org {
without /vesta-1
proxy /flora-1 https://flora-1.web.telegram.org {
without /flora-1
Works - the site answers, you can login and use, everything works.
Version 2 with configuration:
root * /usr/share/caddy/webogram/www
X-Frame-Options SAMEORIGIN
route /venus/* {
route /pluto/* {
route /aurora/* {
uri strip_prefix /aurora
reverse_proxy https://aurora.web.telegram.org
Loads ONLY the first page, authorization does not work, etc.
P.S. In dirs home/choo/apps/caddy/webogram/www & /usr/share/caddy/webogram/www - Identical files are located
P.P.S. Version 1 Caddy server launch as standalone app, Version 2 Caddy launch as docker container
docker-compose.yaml:
version: ‘3’
image: caddy:alpine
- 443:443
- PUID=1000
- GUID=1000
- ./config/Caddyfile:/etc/caddy/Caddyfile
- ./data:/data
- ./sites:/usr/share/caddy
- web
web:
external: true
I don’t understand what that means. Please be more specific.
What URLs are you trying to load? What happens? Any errors in the logs? Can you use curl -v
to show what a request looks like?
You can add access logs to your Caddyfile by adding the log
directive (no arguments) which will output to stdout.
You can check your logs with docker-compose logs caddy
Maybe I’ll try to reformulate the question.
How to do:
query webogram.choodique.me/venus/apiw1 caddy proxied them to Telegram APIs
sorry about my “English”
That’s still not enough information. What isn’t working? What happens instead? What are you seeing in your logs?
