Protect admin endpoint
Hi Guys,
I’m trying to protect “admin” api without any success.
  1. Caddy version (v2.4.6) | docker
My JSON config from api
curl http://172.21.20.8:2019/config/admin
{"enforce_origin":true,"listen":":2019","origins":["secret.admin.too"]}
Admin/Config endpoint is not protected.
(Basicauth could be a perfect fit… but not available).
That’s odd, that used to work. Something must have changed recently.
Fixed here (and refactored some things while I was at it, since the logic could be cleaned up): https://github.com/caddyserver/caddy/commit/40b54434f3cdb804ef10eee0ba5d8d6c390e93d4
Hi,
I still have issue, the new commit work partially.
test> cat admin.json
 "listen": ":2019",
 "origins": ["secret.admin.too"],
 "enforce_origin": true
test> curl -X PATCH -H'Content-Type: application/json'  http://172.21.20.8:2019/config/admin -d @admin.json
test> curl http://172.21.20.8:2019/config/ |jq
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100    59  100    59    0     0    275      0 --:--:-- --:--:-- --:--:--   275
  "error": "client is not allowed to access from origin ''"
## No access
test> curl -X GET -H'Content-Type: application/json' -H'Origin: secret.admin.too'  http://172.21.20.8:2019/config
{"error":"client is not allowed to access from origin 'secret.admin.too'"}
test>
## didn't work :(
I notice … that “secret.admin.too” is stored as “//secret.admin.too” on autosave.json.
curl -X GET -H'Content-Type: application/json' -H'Origin: //secret.admin.too'  http://172.21.20.8:2019/config
#Works !! :)
That’s weird, doesn’t happen for me when I use your exact config and steps shown above:
╔[matt@shadowfax:~/.config/caddy]
╚>$ cat autosave.json
{"admin":{"enforce_origin":true,"listen":":2019","origins":["secret.admin.too"]}}
You probably see //secret.admin.too in the log output:
INFO    admin   admin endpoint started  {"address": "tcp/:2019", "enforce_origin": true, "origins": ["//secret.admin.too"]}
and that is normal/expected. The Origin header value is actually supposed to include a scheme by spec (but Caddy allows you to omit it for convenience to allow any scheme), so the origin is parsed as a URL, and when stringified, it prints // to separate scheme (empty) and host.
So, your request is invalid:
it must include either http:// or https://:
-H'Origin: https://secret.admin.too'
Please see the Origin header docs:
Notice that only a port is optional. Scheme is required.
It makes sens !
Thanks for your quick answer.
