Proper way to use Cloudflare DNS for getting HTTPS cert
2.2.0
Systemd
Built using xcaddy on ubuntu 20.04 using the .deb provided systemd unit
systemctl restart caddy
Stock one on ubuntu
Caddy returns unrecognized directive: DNS
caddy list-modules does however show dns.providers.cloudflare as available
run: adapting config using caddyfile: /etc/caddy/Caddyfile:15: unrecognized directive: dns
What’s in the caddyfile.
tls config is per-site, not global. The Caddyfile is parsing tls as being a site name there.
You can make use of snippets to avoid repetition (also, read the rest of this page in the docs to get a better understanding of the Caddyfile structure):
Ah, see I went through that but it doesn’t mention the tls directive specifically, and that was the only issue I had with the caddyfile
Thanks
