adhisimon
(Adhidarma Hadiwinoto)
#1
v2.4.3
systemctl start caddy.service
RockyLinux 8.4 with systemd
curl -s localhost:2019/metrics|grep caddy_http_response_size_bytes_
n/a
n/a
On exported prometheus monitoring, there are 3 kinds of metrics about caddy_http_response_size_bytes: bucket, count, sum.
What’s the difference of caddy_http_response_size_bytes_count and caddy_http_response_size_bytes_sum?
n/a
n/a
Hi @adhisimon,
The caddy_http_response_size_bytes
metric is a histogram, and so there are a few different metrics exposed about it.
Please read the Prometheus docs on histograms for a full explanation, but to quickly answer your question:
- the
_count
metric is the total number of observations made (i.e. if 50 responses were observed, the value would be 50)
- the
_sum
metric is the sum of all observed values (i.e. if the value of all 50 observed responses were 0.5
, the value would be 25.0
system
(system)
closed
#3
