Debian 10, systemd enabled, no docker - Caddy installed with official non-Docker instructions for Debian
sudo systemctl start caddy
The default systemd service file from /lib/systemd/system/caddy.service:
# caddy.service
# for your installation.
Type=notify
Caddyfile for server #1:
# domain name.
https://hc.klo.ink {
reverse_proxy 127.0.0.1:8000
https://hc2.klo.ink {
reverse_proxy [2001:470:1f07:4d5:123::]:80
Caddyfile for server #2:
# domain name.
respond "Hello there"
I am running Caddy on two identical virtual servers, both on Debian 10. Both are NAT VPS with only limited IPv4 port ranges available to me so I am using Cloudflare to proxy my subdomains to the servers’ IPv6 addresses. On Cloudflare I have the “Full” SSL/TSL Encryption Mode on and two subdomains, hc and hc2, which are both AAAA records pointing to server #1’s IPv6 address with the “orange cloud” proxy on.
The reverse proxy for subdomain hc is working great as it points to a local application on server #1.
The subdomain hc2 points to server #2’s IPv6 address at port 80 where another Caddy instance is running, and I am only getting 502 Bad Gateway trying to access it through the h2 subdomain. I have also tried serving some actual files instead of just respond but it changed nothing. I believe this is a problem with HTTPS but I have tried different configurations for hours without any results.
So how can I make both subdomains work over HTTPS when the hc2 subdomain is served unencrypted HTTP content from an IPv6 address on an another server?
Journal logs for the Caddy service on server #1:
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.6994066,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_addr":"127.0.0.1:56896","headers":{"Accept-Encoding":["gzip"],"Content-Length":["489"],"Content-Type":["application/json"],"Origin":["localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.6996996,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.6997654,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.6997743,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"debug","ts":1641163628.6998854,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"debug","ts":1641163628.6998932,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.6998963,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["hc.klo.ink","hc2.klo.ink"]}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"debug","ts":1641163628.7082253,"logger":"tls","msg":"loading managed certificate","domain":"hc.klo.ink","expiration":1648924536,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"debug","ts":1641163628.7084117,"logger":"tls.cache","msg":"added certificate to cache","subjects":["hc.klo.ink"],"expiration":1648924536,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"dd80abf01626ce658b941d98198d67cbb99dc733a2ad94516821d21e0c6650f9","cache_size":1,"cache_capacity":10000}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"debug","ts":1641163628.7085612,"logger":"tls","msg":"loading managed certificate","domain":"hc2.klo.ink","expiration":1648943999,"issuer_key":"acme.zerossl.com-v2-DV90","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"debug","ts":1641163628.7086964,"logger":"tls.cache","msg":"added certificate to cache","subjects":["hc2.klo.ink"],"expiration":1648943999,"managed":true,"issuer_key":"acme.zerossl.com-v2-DV90","hash":"5aeeed5e12aae3bae5c99515028f3097cebb7aaf63a2269b661eb8eaa1ae05f8","cache_size":2,"cache_capacity":10000}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.7087462,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0001a84d0"}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.7109673,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0000f4540"}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.7157412,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.7157743,"logger":"admin.api","msg":"load complete"}
Jan 02 22:47:08 hippa caddy[1207]: {"level":"info","ts":1641163628.7209148,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
Journal logs for the Caddy service on server #2:
Jan 02 22:55:33 vinyl systemd[1]: Starting Caddy...
Jan 02 22:55:33 vinyl caddy[12241]: caddy.HomeDir=/var/lib/caddy
Jan 02 22:55:33 vinyl caddy[12241]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Jan 02 22:55:33 vinyl caddy[12241]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Jan 02 22:55:33 vinyl caddy[12241]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Jan 02 22:55:33 vinyl caddy[12241]: caddy.Version=v2.4.6 h1:HGkGICFGvyrodcqOOclHKfvJC0qTU7vny/7FhYp9hNw=
Jan 02 22:55:33 vinyl caddy[12241]: runtime.GOOS=linux
Jan 02 22:55:33 vinyl caddy[12241]: runtime.GOARCH=amd64
Jan 02 22:55:33 vinyl caddy[12241]: runtime.Compiler=gc
Jan 02 22:55:33 vinyl caddy[12241]: runtime.NumCPU=1
Jan 02 22:55:33 vinyl caddy[12241]: runtime.GOMAXPROCS=1
Jan 02 22:55:33 vinyl caddy[12241]: runtime.Version=go1.17.2
Jan 02 22:55:33 vinyl caddy[12241]: os.Getwd=/
Jan 02 22:55:33 vinyl caddy[12241]: LANG=C.UTF-8
Jan 02 22:55:33 vinyl caddy[12241]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Jan 02 22:55:33 vinyl caddy[12241]: NOTIFY_SOCKET=/run/systemd/notify
Jan 02 22:55:33 vinyl caddy[12241]: HOME=/var/lib/caddy
Jan 02 22:55:33 vinyl caddy[12241]: LOGNAME=caddy
Jan 02 22:55:33 vinyl caddy[12241]: USER=caddy
Jan 02 22:55:33 vinyl caddy[12241]: INVOCATION_ID=f98192ebbe7d44498802680d68505c63
Jan 02 22:55:33 vinyl caddy[12241]: JOURNAL_STREAM=7:585638051
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"info","ts":1641164133.8453805,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"info","ts":1641164133.849394,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"info","ts":1641164133.8501492,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"debug","ts":1641164133.850857,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"info","ts":1641164133.8535688,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00027cd20"}
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"info","ts":1641164133.8537667,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"info","ts":1641164133.8575718,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"info","ts":1641164133.8576267,"msg":"serving initial configuration"}
Jan 02 22:55:33 vinyl systemd[1]: Started Caddy.
Jan 02 22:55:33 vinyl caddy[12241]: {"level":"info","ts":1641164133.9303508,"logger":"tls","msg":"finished cleaning storage units"}
I have shuffled the Cloudflare SSL/TLS Encryption Mode between Full and Flexible, tried to access both http and https addresses for hc2.klo.ink, served static files with file_server instead of respond on server #2, tried to switch the server roles by pointing the subdomains to server #2 and proxying from there to server #1 (after which I had the same problem for the server #1 application) and a lot of other things I don’t even remember after four hours.
I also tried pointing the hc2 subdomain straight to server #2 in order to separate the servers and have each handle their own subdomain by modifying the Caddyfiles accordingly. But then Caddy could not retrieve a certificate for hc2 at all when server #1 was already running and working well.
