Problems with PowerDNS plugin (Record creation)
I’m migrating from a working Traefik / PowerDNS ACME challenge setup to Caddy a PowerDNS ACME challenge setup with own hosted PowerDNS servers.
I have installed the PowerDNS plugin and try to generate LetsEncrypt certificates with it but this errors in a strange way. When I start Caddy it tries to generate the certificates but it errors and cannot create the needed PowerDNS records because of a “unsupported protocol scheme”
Caddy:
| {"level":"error","ts":17135456667.9905512,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.domain.tld","issuer":"acme-staging-v02.api.letsencrypt.org-directory","error":"[*.domain.tld] solving challenges: presenting for challenge: adding temporary record for zone \"domain.tld.\": Get \"my.dns.tld:8081/api/v1/servers/localhost/zones?zone=domain.tld.\": unsupported protocol scheme \"my.dns.tld\" (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/168320304/52825046623) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
PowerDNS
Dec 09 02:11:04 Lua record monitoring declaring TCP/IP 111.111.111.111:443 DOWN: connecting to 111.111.111.111:443 failed: Connection refused
Dec 09 02:11:09 Lua record monitoring declaring TCP/IP 111.111.111.111;443 UP!
Running in Docker on Ubuntu
docker stack deploy -c ./caddy/docker-compose.yml caddy
FROM caddy:2.7.5-builder AS builder
RUN xcaddy build \
        --with github.com/mholt/caddy-l4 \
        --with github.com/caddy-dns/powerdns
FROM caddy:2.7.5
version: "3.7
    image: myregistry/repo/caddy:2-staged
    restart: always
    deploy:
      replicas: 3
      placement:
        constraints:
          - node.role == manager
    command: caddy run --config /config/caddy-config.json
      - 80:80  # Needed for the ACME HTTP-01 challenge.
      - 443:443
      - /caddy/config:/config
#      - /caddy/config/Caddyfile:/etc/caddy/Caddyfile
      - /caddy/config/caddy-config.json:/config/caddy-config.json
      - /caddy/data:/data
    "logging": {
        "sink": {
            "writer": {
                "output": "stdout"
        "logs": {
                "writer": {
                    "output": "stderr"
                "level": "DEBUG"
    "apps": {
        "tls": {
            "certificates": {
                "automate": [
                    "*.mydomainname.tld"
            "automation": {
                "policies": [
                        "issuers": [
                                "module": "acme",
                                "ca": "https://acme-staging-v02.api.letsencrypt.org/directory",
                                "challenges": {
                                    "dns": {
                                        "provider": {
                                            "name": "powerdns",
                                            "server_url": "123.123.1234.123:8081",
                                            "api_token": "myapikey",
                                            "debug": "stdout"
                                        "resolvers": [
                                            "123.123.1234.123:53"
                                        "propagation_delay": 60000
                                    "http": {
                                        "disabled": true
                                    "tls-alpn": {
                                        "disabled": true
        "layer4": {
            "servers": {
                "mydomainname.tld": {
                    "listen": [
                        ":80",
                        ":443"
                    "routes": [
                            "match": [
                                    "ip": {
                                        "ranges": [
                                            "111.111.111.111"
                                    "http": [
                                            "host": [
                                                "mydomainname.tld"
                            "handle": [
                                    "handler": "proxy",
                                    "upstreams": [
                                            "dial": [
                                                "nginx_nginx:80"
                            "match": [
                                    "ip": {
                                        "ranges": [
                                            "111.111.111.111"
                                    "tls": {
                                        "sni": [
                                            "mydomainname.tld"
                            "handle": [
                                    "handler": "tls"
                                    "handler": "proxy",
                                    "proxy_protocol": "v1",
                                    "upstreams": [
                                            "dial": [
                                                "nginx_nginx:80"
                "secure-imap": {
                    "listen": [
                        "0.0.0.0:993"
                    "routes": [
                            "handle": [
                                    "handler": "tls"
                                    "handler": "proxy",
                                    "upstreams": [
                                            "dial": [
                                                "mailserver_mailserver:143"
                "normal-imap": {
                    "listen": [
                        "0.0.0.0:143"
                    "routes": [
                            "handle": [
                                    "handler": "proxy_protocol"
                                    "handler": "proxy",
                                    "proxy_protocol": "v2",
                                    "upstreams": [
                                            "dial": [
                                                "mailserver_mailserver:1143"
I don’t recognize that error :frowning:
It must be somekind of PowerDNS-specific problem, but I don’t know much about PowerDNS. Sorry.
The Github issue will likely be your best recourse.
The actual implementation is at GitHub - libdns/powerdns: libdns powerdns provider, the caddy-dns repo is just bindings plugin bindings for Caddy.
Thanks! I need to ask PowerDNS I’m sure but it could be libdns as well but didn’t want to bother them yet before I knew more.
I will ask both and see what their responses are and update here!
@francislavoie OK solved! The API needs to be accessed by http(s):// which is a little bit unclear in the docs as it’s not explicit stated there. Can “we” add this ?
Do you mean in "server_url" in the config?
Yeah, you can open a PR to fix the README for the plugin, I can merge that.
Indeed that is what I meant.
I will create PR for it asap!
Thanks again!
