Problems with Porkbun DDNS
I’ve set up Porkbun DDNS as best I can, but caddy logs seem to indicate a 404 while caddy attempts to run DDNS.
{"level":"info","ts":1702090197.6680722,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1702090197.6735327,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702090197.6741238,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000494800"}
{"level":"info","ts":1702090197.6742337,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1702090197.6742768,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"debug","ts":1702090197.6743395,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"subjects":["segfault.foo"]},{}]}},"http":{"servers":{"remaining_auto_https_redirects":{"listen":[":80"],"routes":[{},{}]},"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"static_response","headers":{"Location":["https://www.github.com"]},"status_code":302}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{}}}}}
{"level":"debug","ts":1702090197.6747334,"logger":"dynamic_dns","msg":"beginning IP address check"}
{"level":"info","ts":1702090197.6748075,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1702090197.6750836,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"debug","ts":1702090197.6753607,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
{"level":"info","ts":1702090197.6754165,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"debug","ts":1702090197.6755,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
{"level":"info","ts":1702090197.6755354,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1702090197.6755576,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["segfault.foo"]}
{"level":"debug","ts":1702090197.6761706,"logger":"tls","msg":"loading managed certificate","domain":"segfault.foo","expiration":1709859590,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/data/caddy"}
{"level":"debug","ts":1702090197.676688,"logger":"tls.cache","msg":"added certificate to cache","subjects":["segfault.foo"],"expiration":1709859590,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"3dcb7fa5313839dc861a4beb7f67d4d788e281c051d2e1763034dfb870316d8b","cache_size":1,"cache_capacity":10000}
{"level":"debug","ts":1702090197.6767826,"logger":"events","msg":"event","name":"cached_managed_cert","id":"8b1d5524-9078-4cf2-97e0-339ad2f52a83","origin":"tls","data":{"sans":["segfault.foo"]}}
{"level":"info","ts":1702090197.677016,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1702090197.6770778,"msg":"serving initial configuration"}
{"level":"warn","ts":1702090197.6792114,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"c76ec936-26a4-49af-9f32-4138d14a852b","try_again":1702176597.6792073,"try_again_in":86399.999999375}
{"level":"info","ts":1702090197.6793919,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1702090198.3521965,"logger":"dynamic_dns","msg":"domain not found in DNS","domain":"segfault.foo"}
{"level":"info","ts":1702090198.352261,"logger":"dynamic_dns","msg":"domain not found in DNS","domain":"segfault.foo"}
{"level":"info","ts":1702090198.35227,"logger":"dynamic_dns","msg":"domain not found in DNS","domain":"www.segfault.foo"}
{"level":"info","ts":1702090198.352276,"logger":"dynamic_dns","msg":"domain not found in DNS","domain":"www.segfault.foo"}
{"level":"debug","ts":1702090198.3523736,"logger":"dynamic_dns","msg":"looked up current IPs from DNS","lastIPs":{"segfault.foo":{"A":[""],"AAAA":[""]},"www.segfault.foo":{"A":[""],"AAAA":[""]}}}
{"level":"debug","ts":1702090198.55374,"logger":"dynamic_dns.ip_sources.simple_http","msg":"lookup","type":"IPv4","endpoint":"https://ipconfig.io/ip","ip":"159.65.33.225"}
{"level":"info","ts":1702090198.5538085,"logger":"dynamic_dns","msg":"updating DNS record","zone":"segfault.foo","type":"A","name":"@","value":"159.65.33.225","ttl":3600}
{"level":"info","ts":1702090198.5538187,"logger":"dynamic_dns","msg":"updating DNS record","zone":"segfault.foo","type":"A","name":"www","value":"159.65.33.225","ttl":3600}
{"level":"error","ts":1702090198.6356988,"logger":"dynamic_dns","msg":"failed setting DNS record(s) with new IP address(es)","zone":"segfault.foo","error":"Invalid http response status, <!DOCTYPE html>\n<html lang=\"en\">\n<head>\n<title>Error</title>\n<style type=\"text/css\">\n\n::selection{ background-color: #E13300; color: white; }\n::moz-selection{ background-color: #E13300; color: white; }\n::webkit-selection{ background-color: #E13300; color: white; }\n\nbody {\n\tbackground-color: #fff;\n\tmargin: 40px;\n\tfont: 13px/20px normal Helvetica, Arial, sans-serif;\n\tcolor: #4F5155;\n}\n\na {\n\tcolor: #003399;\n\tbackground-color: transparent;\n\tfont-weight: normal;\n}\n\nh1 {\n\tcolor: #444;\n\tbackground-color: transparent;\n\tborder-bottom: 1px solid #D0D0D0;\n\tfont-size: 19px;\n\tfont-weight: normal;\n\tmargin: 0 0 14px 0;\n\tpadding: 14px 15px 10px 15px;\n}\n\ncode {\n\tfont-family: Consolas, Monaco, Courier New, Courier, monospace;\n\tfont-size: 12px;\n\tbackground-color: #f9f9f9;\n\tborder: 1px solid #D0D0D0;\n\tcolor: #002166;\n\tdisplay: block;\n\tmargin: 14px 0 14px 0;\n\tpadding: 12px 10px 12px 10px;\n}\n\n#container {\n\tmargin: 10px;\n\tborder: 1px solid #D0D0D0;\n\t-webkit-box-shadow: 0 0 8px #D0D0D0;\n}\n\np {\n\tmargin: 12px 15px 12px 15px;\n}\n\n</style>\n</head>\n\n\n<body>\n\t<div id=\"container\">\n\t\t<h1>An Error Was Encountered</h1>\n\t\t<p>The URI you submitted has disallowed characters.</p>\t\t<p>You can probably find what you're looking for on our <a href=\"/\">homepage</a>.</p>\n\t</div>\n</body>\n</html>\n"}
{"level":"info","ts":1702090198.6357787,"logger":"dynamic_dns","msg":"finished updating DNS","current_ips":["159.65.33.225"]}
v2.7.6 from Docker
I’m using a Caddy custom-built Docker image. My Dockerfile looks like this:
FROM caddy:builder AS builder
RUN xcaddy build \
    --with github.com/mholt/caddy-dynamicdns \
    --with github.com/caddy-dns/porkbun
FROM caddy:latest
#COPY sites /srv
and my docker-compose.yaml looks like this:
  # Using a custom caddy here to make sure we have Porkbun certificate support and DDNS
    build:
      context: .
      dockerfile: ./Dockerfile
      - ./caddy-data/certs:/certs
      - ./caddy-data/config:/config
      - ./caddy-data/data:/data
    network_mode: "host"
Running in Docker (on Ubuntu if that makes a difference, although it shouldn’t)
# (if I need to destroy the previous caddy build)
docker stop caddy && docker rm caddy && docker rmi caddy-caddy:latest
# to build and run
docker compose up -d
(see above)
        acme_dns porkbun {
                api_key <api key>
                api_secret_key <api secret key>
        dynamic_dns {
                ip_source simple_http https://ipconfig.io/ip
                ip_source simple_http https://icanhazip.com
                ip_source interface eth0
                provider porkbun {
                        api_key <api key>
                domains {
                        segfault.foo @ www
                versions ipv4
                check_interval 5m
                ttl 1h
segfault.foo {
        redir https://www.github.com
(I actually have a larger Caddyfile but this is a minimum reproducible example for me)
None that I can think of.
Whoa, that’s a strange error.
There’s probably a bug with GitHub - libdns/porkbun, it might not properly support setting A records and might only handle TXT records correctly.
Best if you open an issue on github to track that.
